fuel injectors
Old Jul 28, 2004 | 07:16 PM
Bintegra's Avatar
Default fuel injectors
my friend has a 1998 Honda civic ex and he needs to change the fuel injectors nut he doesnt know how, can any of yall tell me the steps in changing them. THANKS
Old Jul 28, 2004 | 07:27 PM
HondaHemp's Avatar
Default Re: fuel injectors (Bintegra)
If he you guys cant figure it out , better take it to a hondaguy! Whats mods is he doing to require different injectors? I can tell you how but you have to be serious.
Old Jul 29, 2004 | 07:10 AM
Bintegra's Avatar
he's right in the middle of turbocharging it.
Old Jul 29, 2004 | 03:59 PM
Bintegra's Avatar
Default Re: (Bintegra)
well we tried to insatll them but it turns out that we had the wrong injectors, so now we was wondering what would happen if we used the stock injectors.
Old Jul 29, 2004 | 05:24 PM
B16Drag's Avatar
if you use the stock injectors make sure you at least have enough fuel... I'd suggest you do it right the frist time and get DSM 450ccs or RC 440ccs
Old Jul 29, 2004 | 06:27 PM
HondaHemp's Avatar
If he is doing the turbo kit then he should be able to put injectors in.
Old Jul 29, 2004 | 06:38 PM
B16Drag's Avatar
lets hope so...
Old Jul 29, 2004 | 07:15 PM
Bintegra's Avatar
yea, the injectors my friend got was from a rx-7, i dont know why he got them , so we are debating weather to run stock injectors or not.
Old Jul 29, 2004 | 07:28 PM
B16Drag's Avatar
rx-7 turbo?
Old Jul 29, 2004 | 07:36 PM
Bintegra's Avatar
Default Re: (B16Drag)
i think so
Old Jul 29, 2004 | 07:41 PM
ABK's Avatar
ABK
ahhh, wtf, I don't think it will work. Get some dsm injectors could get them for less the $50.
Old Jul 29, 2004 | 07:48 PM
Bintegra's Avatar
i heard somewhere that if you run stock injectors, with a turbo, your engine will blow, is that true
Old Jul 29, 2004 | 07:56 PM
honda9369's Avatar
yes because it will run lean and that will **** up your motor
Old Jul 29, 2004 | 08:07 PM
civic396's Avatar
Default Re: (honda9369)
even if you get it tuned.
Old Jul 29, 2004 | 08:11 PM
B16Drag's Avatar
tell me what u are using for fuel management? if u say FMU, you can probably use it temporarily and then get uberdata or hondata later... FMU is NOT a good solution to fuel managemnet
boostedteg4dr
May 5, 2009 02:57 PM
mattwl
Honda Civic (2001 - 2005)
10
Dec 6, 2007 06:09 PM
russianswty
27
Nov 14, 2006 06:30 PM
B_1_8_hatch
Sep 12, 2003 11:23 AM
