Pics of the build...
Old Jul 28, 2004 | 06:38 PM
sleepin91teg's Avatar
Default Pics of the build...
Modified by sleepin91teg at 11:09 PM 7/28/2004
Old Jul 28, 2004 | 06:41 PM
Default Re: Pics of the build... (sleepin91teg)
The head is a PR4 B18A1 that has...
brand new valves, 5 angle valve job
Crower Dual springs
Port matched runners
Milled .020"
Hot tanked, and Glass beaded
All new valve seals and plgs
Ill post more pics soon, of the other stuff!
Old Jul 28, 2004 | 06:57 PM
EKhatch's Avatar
Forgive me as I am not familiar with these heads but is it normal for the two middle head studs to stick up further and the tips of the valves to stick up that far past the retainers?
Thanks, looks like fun.
Old Jul 28, 2004 | 07:03 PM
Default Re: Pics of the build... (EKhatch)
That is correct the 2 middle Head studs (ARP studs by the way) stick up further than the rest simply because of the cast of the head...The top Stud is the #1 stud and the bottom is the #2 stud...both of them are taller studs cuz the cast of the head is higher up...Thanx for the opinion!
Old Jul 28, 2004 | 07:07 PM
I guess your not cool with out a pink Valve cover...BTW i have 2 valve covers, one is black and this is the other one!!! just for ***** and giggles!
Old Jul 28, 2004 | 07:20 PM
Eviloliv3's Avatar
youll see in the last pic that the studs come out the same amount all over, its just the design of the head
Old Jul 28, 2004 | 07:25 PM
AllMotorDA9's Avatar
ditch the old school ls i/m and go with the skunk2 , espically if you plan on using bigger cams, like you should with your current set-up.
Old Jul 28, 2004 | 07:28 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepin91teg &raquo;</TD></TR><TR><TD CLASS="quote">I guess your not cool with out a pink Valve cover...BTW i have 2 valve covers, one is black and this is the other one!!! just for ***** and giggles!
That would be halarious to smoke some ricer or domestic punk and then show him what's under the hood. lol
Old Jul 28, 2004 | 07:32 PM
EKhatch, thats the right idea! haha its just a joke tho i have a black one for regular days...and the comment about the skunk2 IM id like to, just havent gotten around to the money yet:-/ being a student sux sometimes...but i have the crower 403 cams so the cams are already here...thanx
Old Jul 28, 2004 | 08:13 PM
navin's Avatar
where'd you get the paint for the valvecover, pink is kewl!!
Old Jul 28, 2004 | 08:38 PM
tnt007's Avatar
cute valvecover lol
Old Jul 28, 2004 | 08:42 PM
91' LS-VTEC's Avatar
Default Re: Pics of the build... (navin)
lookin good.
pink, its the new black
Old Jul 28, 2004 | 08:58 PM
The Destroyer's Avatar
Default Re: Pics of the build... (91' LS-VTEC)
I have some pretty aggressive cams for sale, Webcams. Ill get pics, I will let them go very cheap.
Old Jul 29, 2004 | 02:09 AM
mornin' bump im loving the feedback!
Old Jul 29, 2004 | 03:58 AM
JimmyAtlantis's Avatar
Nice rebuild, pinky! Looks good
Old Jul 29, 2004 | 12:31 PM
Default Re: Pics of the build... (JRI94)
Awesome...i thought i was gonna get flamed for the pink valve cover...im heading to the garage for more work...ill post pics tonight
Old Jul 29, 2004 | 06:08 PM
Damn it...i started it tonight...and it sounded like **** so i shut if off...and ran a compression test...from right to left (4-3-2-1) i got this...
| 20 | 135 | 30 | 115 |
The head cant be the problem, all new valves, and all were lapped in...also a new head gasket and copper spray...ARP head studs and trq'd to 70 ft lbs...stock bottom end, bottom end didnt have a problem before i did the head build, so why would it now!?!?
Help
Old Jul 29, 2004 | 06:26 PM
non-VTEC's Avatar
wow those are horrible compression numbers.
what valves are those and who installed them? did the properly machine/grind them to fit that head?
check your cam timing first.
then check to see that your valve lash isnt to tight causeing the valves not to close completly.
Old Jul 29, 2004 | 06:28 PM
Default Re: Pics of the build... (non-VTEC)
Whoa, too much to know...i dont know much about what you said...the valves are OEM valves brand new..and lapped into the head...mmm dont know how to check the rest...cam timing tho is fine, the cam gears and crank pulley are all lined up...that wouldnt affect compression #'s though...would it?
Old Jul 29, 2004 | 06:36 PM
non-VTEC's Avatar
damn man......you put the head on the car and you dont know how to check valve lash?
i can guarentee that all of your lifters are out of spec and causing the valves to stay open. (provided that your timing belt all lines up correctly like you say)
you need to get measure the clearence between the base circle of the cam lobe and the lifter face and make the adjustment. you need the right size feeler guages to do this. you should use the helms manual to do this procedure if your unsure.
once you remove the cams and lifters from the head your always supposed to re-adjust the valve lash.
hope it works out.
Old Jul 29, 2004 | 06:38 PM
I have the helms manual on my computer, ill check it out...you think this is the problem...cuz my first guess was pistons...and i dont have th money for that right now!!! ill check the helms and see what i can do...!! Thanx
Old Jul 29, 2004 | 06:43 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
like non-VTEC said "valve lash". my money is also on your valves esp since they are new and you put in different cams. even if you just change to a different set of valves or mix your old ones around...you will have to readjust your valves.
non-VTEC's Avatar
well when you removed the cams and the lifters did you mix them all up? or did you keep them in order? did you just put them into any spot when assembling the head again?
if you just mixed them all up it's probably the valve lash.
Old Jul 29, 2004 | 06:49 PM
In the helms manual i see section 6-3 titled "valve adjustment" is that the valve lash you speak of? i didnt totaly mix it all up...the lifters on the intake side were put into a bag and labeled intake, and the exhaust in a bag labeled exhaust...but not cylender specific:-/ Thanx
Old Jul 29, 2004 | 07:09 PM
wreckedmyteg's Avatar
Valve adjustment.
If it's not that your SOL an you'll probably have to pull the head again. That means a new head gasket. Sucks doesn't it.
