need help all yall tranny guru's
Ok. frist i herd somthing that sounded like it was rubbing so i looked around and it sound like it was coming from were the diff. is in the tranny so i took the tranny out and opened it up and saw that the bottom of the counter shaft were the gears are there were 3 teeth broken off so i put a new 1 in and put the tranny back in the car and low and be hold the sound was back so out came the tranny again open looked around. It was fine so some one told me to change the bearings in the bell houseing so i got a new bell houseing with bearings and put it back in the car and the ******* thing is still rubbing so i looked around on honda tech to see if any body had the same luck i could find no so i took it out 1 last time and took the counter shaft to a place called just hondas or some **** like that and they looked at it and said it mite be the top bearing on the counter shaft so i bought that 1 and the one under that one just in case put it back in and the car is still sounds like it rubbing it sounds like it rubbing just when you have your foot off of the gas or when you put it in neutral. if you can help me thank you.
