headlights
Old Jul 28, 2004 | 06:13 PM
franks98civic's Avatar
Default headlights
I bought some after market headlights for my civic and I cant keep the moisture out of them. I took them out and put silicone all around the seal and I am still getting moisture inside. I hope someone could maybe give me a few suggestions.
Old Jul 28, 2004 | 06:53 PM
ice11honda's Avatar
Default Re: headlights (franks98civic)
I had the same problem with my projector headlights I bought. I pulled the entire lens cover off and cleaned out the old sealant. Then I rtv silicon to seal it back and worked for me.
Old Jul 28, 2004 | 07:16 PM
ek9800's Avatar
Default Re: headlights (ice11honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ice11honda &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem with my projector headlights I bought. I pulled the entire lens cover off and cleaned out the old sealant. Then I rtv silicon to seal it back and worked for me.</TD></TR></TABLE>
Old Jul 30, 2004 | 06:40 AM
zinn43731's Avatar
How do you seperate the lens from the casing and what do you use to clean up the sealant? I don't want to put something on the lights that will damge them.
THANKS.
Old Jul 30, 2004 | 07:25 AM
94solchick's Avatar
Default Re: headlights (zinn43731)
What kind of headlights are they?? I have aftermarket headlights, and I've never had that problem, I did with the clear corners, but that's probably because I don't have fender wells in the front...I drilled a tiny hole in the bottom corner, and it was fine.
Old Aug 4, 2004 | 05:21 PM
ice11honda's Avatar
Just put the headlights in your oven. bake aroung 250 for like 5-6 minutes. sounds crazy but works. then use a flathead to pry the lens cover away.you will have to reheat a few times to soften the sealent again to get it off. use either a flathead or whatever else u can find to run along the groove that will scrap the sealant off. put down foil or something in the oven so u dont get that **** on the oven racks haha.
361 accord
Jan 26, 2007 02:40 PM
jdm93cx
Honda S2000
Oct 19, 2005 09:43 AM
SIcivicHATCH
Jan 13, 2005 05:57 AM
jond
Jan 7, 2004 11:12 AM
sean96gsr
Apr 8, 2003 11:40 AM
