195/55 on 15X7 rim???
Old Nov 27, 2001 | 10:51 AM
REVolution's Avatar
Default 195/55 on 15X7 rim???
I have a set of winter tires in 195/55-15 and recently found an old set of wheels in my garage that are 5x114, but 15X7. Can I run the 195 series tire on this rim for the winter???
TIA,
Chris
Old Nov 27, 2001 | 10:57 AM
Cosworth's Avatar
Default Re: 195/55 on 15X7 rim??? (REVolution)
Yeah they fit absolutely flush with the rim. BTW, make sure you get a correct offset-ed rims.
Old Nov 27, 2001 | 11:13 AM
nsxtcjr's Avatar
New User
Default Re: 195/55 on 15X7 rim??? (Cosworth)
You'll also want to make sure the center bore (the diameter of the center hole) is the same.
Old Nov 27, 2001 | 02:38 PM
REVolution's Avatar
Thanks for the help. I do need to confirm the off-set, though.
Chris
Old Nov 27, 2001 | 05:54 PM
gamby's Avatar
Depends on the tires--my 195/55HR-15 Michelin Arctic Alpin Pilots absolutely BULGE off of my 15x6.5 Slipstreams. They'd be fine on 15x7's, but again, not sure about your particular tires.
Old Nov 27, 2001 | 06:15 PM
REVolution's Avatar
Well, I checked the off-set...they are +36. Will this work?
TIA,
Chris
LudemanDan
10
Oct 23, 2005 11:17 AM
hellshock2182
Apr 30, 2005 01:36 PM
AWD: Jeff
Aug 27, 2004 12:31 AM
B-B-K
11
Aug 2, 2004 06:29 PM
M-EJ1
Apr 8, 2003 08:30 AM
