Intake Manifold Design thoughts...
Old Jul 28, 2004 | 04:22 PM
ranta18's Avatar
Default Intake Manifold Design thoughts...
Also posted on RM forum...
I've been looking into some tech info on intake manifold design and runner length. What do you guys think of this http://www.grapeaperacing.com/...s.pdf
Runner length = ((Effective cam duration * 0.25 * Pressure wave speed * 2) / (Peak power RPM + Reflective Value)) - 0.5 * Runner diameter
What do you consider to be the effective cam duration? 720 - (Advertised duration - 10,20, or 30 degrees?)
What do you use for pressure wave speed? 1200,1250,1300 ft/s?
What pressure wave / reflective value do you tune for? 3,4?
Do you consider this to be a good equation for Honda engines?
For my engine making peak power at 9000 rpm, using a effective cam duration of 445 degrees, 1300 ft/s wave speed, 1.75" diameter runner, and using the 3rd pressure wave, its comes out to 9.36" for the runner length. BUT that includes the distance from the head to the valve which is 3.12", so the actual intake manifold runner length would calculate to 6.25" long. Make it a 2" diameter runner and its 6.58" long. By going off that equation, I'm thinking of a manifold with runners that taper from 2" diameter to stock size with runners that can be adjusted from 6" to 7" long to get an exact tune on the dyno would be great. 4" diameter plennum with a 70mm TB also.
What do you think about the way the runners enter the manifold? One engine builder / genius said to make them come in flat with the manifold and not to put velocity stacks inside.
Thanks
Old Jul 28, 2004 | 04:46 PM
ranta18's Avatar
Default Re: Intake Manifold Design thoughts... (ranta18)
Also, whats a good explaination why the manifold runners are shorter than ITB runners?
Old Jul 29, 2004 | 04:06 PM
ranta18's Avatar
Anyone? Thoughts?
I've got the answer to the manifold vs ITB's question.
Digitalis
Jul 28, 2016 07:55 AM
thunderboy
Jul 19, 2008 06:10 PM
solorexer
Jun 17, 2002 10:37 AM
TheShad0w
Apr 1, 2002 06:55 PM
93B17A
Nov 24, 2001 06:26 PM
