H-22 intake manifold for h-22 civic hybrids
Old Jul 28, 2004 | 04:16 PM
Ur 2 Slow 4 J's Avatar
Default H-22 intake manifold for h-22 civic hybrids
does anyone know wtf skunk 2 will have their intake manifold foir us hybrids. i wanna go with the euro accord, but i dont want to worry about the mods. i have skunk 2 valvetrain/retainers and cams and i liek them so i wanna keep with them.
Old Jul 28, 2004 | 05:04 PM
Quick99Si's Avatar
Default Re: H-22 intake manifold for h-22 civic hybrids (Ur 2 Slow 4 J)
From pictures that I've seen, both the Skunk2 and the Euro-R intake manifolds would be too big for 92-00 Civics, which is a shame. The Skunk2 IM has fitment issues on Preludes let alone our puny cars... the install pics show the IM almost hitting the firewall and attached components.
I think our only hope would be to go with a different set of motor mounts. HCP/Hasport seem to push the engine as far back as possible (weight balance and performance reasons I assume) BUT it kinda limits our choices for aftermarket intake manifolds.
Does anyone actually have a different IM in an H22 EG or EK chassis, not incl ITB's?
ps- why would you worry about the Skunk2 valvetrain/cams not working with the Euro-R IM?
Adi
Old Aug 1, 2004 | 12:45 PM
Default Re: H-22 intake manifold for h-22 civic hybrids (Quick99Si)
im not worries, i just like skunk 2 and i wanna stay with skunk 2 and the original post was has anyone heard about the skunk 2 IM
Old Aug 1, 2004 | 02:03 PM
2point6's Avatar
The Euro R is shorter than the stock Manifold and it will fit in a EG.
Old Aug 1, 2004 | 02:43 PM
H25's Avatar
H25
Default Re: H-22 intake manifold for h-22 civic hybrids (2point6)
the euro r swap fit perfect in my hatchback. i didnt have any fitment problems.
Old Aug 1, 2004 | 04:32 PM
chris_m's Avatar
* B A N N E D *
Default Re: H-22 intake manifold for h-22 civic hybrids (MHRacing-310)
Or just get your manifold ported
Old Aug 1, 2004 | 07:12 PM
Westrock2000's Avatar
Default Re: H-22 intake manifold for h-22 civic hybrids (alld16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alld16a &raquo;</TD></TR><TR><TD CLASS="quote">Or just get your manifold ported</TD></TR></TABLE>
That thing where they flow the abrasive compound through it would be best (ports everywhere in it, not just the parts you can see...and its even)...can't remember the name right now...
Old Aug 1, 2004 | 09:23 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: H-22 intake manifold for h-22 civic hybrids (Westrock2000)
You can always take a hammer to the firewall.
I have heard of people who custom make their own mounts and pound in the firewall in order to get a near-perfect axle angle.
Old Aug 2, 2004 | 02:24 PM
4drsedaneg's Avatar
hes talking about extrude honing it, it would be an exelent option for the stock or any mani, but its wicked expensive, but then again they can enlarge the whole mani an runners to the same thicknes to like +/- .001 and they can make some insane surface finishes
Old Aug 2, 2004 | 04:28 PM
Default Re: H-22 intake manifold for h-22 civic hybrids (4drsedaneg)
There are places that can do it locally usually. Yes Extrude Hone was the name...but thats the official company that started it. Getting a generic "abrasive porting" will work just as well, as certainly better than any die grinder work (assuming the normal shape is good).
Old Aug 2, 2004 | 05:52 PM
cpforyou's Avatar
According to the other thread, the Skunk2 Intake Manifold is 30mm longer. After doing some measurements, there's no way I believe it can fit. It will totally hit my lines.
Old Aug 2, 2004 | 05:59 PM
CallMeJesus's Avatar
Default Re: (cpforyou)
30mm isnt enough room? when i did an h22/eg swap i could slide my closed fist behind the IM. hell, we even put AC back onto the car, with no interference problems.
why would you want an IM with longer runners? thats gonna cost you power on the top, and the h22 makes too much bottom end torque for you to worry about making more. you want an intake manifold with runners about 3" long, shooting at a slight upward angle, this way the injector sits lower and can shoot a smoother stream more towards the back on the intake valve, for better valve cooling and atomization.
but then again, when that h22 civic went to the local drag strip, everybody thought the swap was done by Honda themselves.
Old Aug 2, 2004 | 07:03 PM
k_spek's Avatar
Default Re: (CallMeJesus)
With most of the mount kits out there (hcp and hasport being the main ones) there is a little manifold to firewall clearance, but there is almost no manifold to brakeline clearances. With my hcp kit and stock h22 intake manifold, the the tps sensor was VERY close to one of the brake lines and only cleared because of the way it was bent from the factory. Now the hasport kit generally puts the motor farther forward more giving you alittle more firewall to manifold clearance. There is enough clearance for the EURO R manifold with an h22 civic, but the problem is that the IACV, mounted in its stock location, hits the brakelines. And since you need to use an adapter bracket to mount a two wire IACV on the manifold, it pushed the IACV even farther out. So you have to either rebend the brake lines or run a remotely located IACV. I do not know how the much different the Skunk2 manifold is from the EURO R manifold, but I think it is going to have the same fitment issues with IACV as does the EURO R manifold in civic engine bays.
Old Aug 3, 2004 | 06:04 PM
k_spek's Avatar
Default Re: (laugHin22CX)
Ok after seeing the pics of the manifold, I see they got around the fitment issues by relocating the IACV off the manifold. The manifold looks pretty good. Too bad there isn't any EGR. O well...better performance right? Hehe.
NirVTEC
13
Jun 14, 2005 10:05 PM
Twin-cam
Dec 15, 2004 11:03 PM
jdmcivicferio
Aug 18, 2004 02:07 PM
