tps or not
Would an incorrect tps signal cause an engine not to start? I had to replace the tps on my TB before i swapped in the motor, Because the other one was broken, so when i put the new one on, i just centered it? The tps came from a obd2 civic, and i am using an obd1 ecu and wiring harness? will this make any difference either?
you should re-calibrate it asap, to eliminate a few possibilities, is everything plugged in correctly, did you just do a swap or did you simply replace the sensor?
yeah i did a swap. It ran for a few mins, but it doesn't run now. I did a intake mani gasket replacement, and now it won't run at all. It had a bad intake leak from the manifold, not it doesn't have a leak, and it won't run?
it cranks, but it won't start. After the install of the new gasket, it ran for about 10 seconds, then died. I noticed to come to think of it, that one of the injector clips had not been on all the way, so i plugged it back in, but after that, it would not start al all. I reset the ecu, but the only code i have is code 10, and it still won't start?
aznfreakyguy
Jul 3, 2011 12:24 AM
Alexpbnj
Dec 6, 2010 02:52 PM
