Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
YES I SEARCHED - 2 quick ITR TRanny Questions - Racing oriendted
Old Jul 28, 2004 | 11:40 AM
B HATCH's Avatar
Default YES I SEARCHED - 2 quick ITR TRanny Questions - Racing oriendted
1) I got a brand new tranny in the box, so i want to know if i have to brake in a tranny before i go pownd away at it during autocross or a track day.
2) What tranny fluid should i use? Honda stuff is ok for street but what about those track days.
Modified by B HATCH at 11:20 PM 7/28/2004
Old Jul 28, 2004 | 12:12 PM
.RJ's Avatar
.RJ
Default Re: YES I SEARCHED - 2 quick ITR TRanny Questions - Racing oriendted (B HATCH)
There was just a topic on tranny fluid..... https://honda-tech.com/zerothread?id=931423
Anyways, I'm using Motul Gear300 (75w90), no problems here. Any synthetic fluid should do - the Honda fluid is a 75w80, just do some research on the viscosity of the fluid you're looking to use to make sure its not too thick (90w is a big range).
Old Jul 28, 2004 | 12:15 PM
Littleton's Avatar
Before you start power shifting on your ITR tranny...Maybe you should do what the best drivers in the world do and shift with two finger tips and perfect being smooth with your shifts.
Old Jul 28, 2004 | 12:18 PM
B HATCH's Avatar
Default Re: YES I SEARCHED - 2 quick ITR TRanny Questions - Racing oriendted (Littleton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littleton &raquo;</TD></TR><TR><TD CLASS="quote">Before you start power shifting on your ITR tranny...Maybe you should do what the best drivers in the world do and shift with two finger tips and perfect being smooth with your shifts.</TD></TR></TABLE>
i use a ladies driver gloves....so that i can have the delicate feminine touch.
Thanks for the link i will try the MOTUL
Old Jul 28, 2004 | 02:36 PM
chad's Avatar
Moderator
Default Re: YES I SEARCHED - 2 quick ITR TRanny Questions - Racing oriendted (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Anyways, I'm using Motul Gear300 (75w90), no problems here. Any synthetic fluid should do - the Honda fluid is a 75w80, just do some research on the viscosity of the fluid you're looking to use to make sure its not too thick (90w is a big range).</TD></TR></TABLE>
WRONG....and you are gonna KILL YOUR ITR TRANNY WITH THAT HEAVY OF OIL RJ!!!
honda uses mobil 30 weight or 10/30 oil!!!!!!!!!!!
Old Jul 28, 2004 | 02:38 PM
.RJ's Avatar
.RJ
Default Re: YES I SEARCHED - 2 quick ITR TRanny Questions - Racing oriendted (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">WRONG....and you are gonna KILL YOUR ITR TRANNY WITH THAT HEAVY OF OIL RJ!!!</TD></TR></TABLE>
Riiiiiight....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">honda uses mobil 30 weight or 10/30 oil!!!!!!!!!!!</TD></TR></TABLE>
Which is a 75w80 gear oil equivalent. Motul gear 300 would be a 10w40 equivalent.
Honda doesnt recommend using motor oil anymore for any length of time - some of the anti-wear additives used in the MTF cannot be used in Engine oil (to meet current specifications, I think SJ), so Honda sells MTF. Its non-detergent 10w30 motor oil with a few additives, nothing special. The "honda" oil is made by Mobil as well, but again its nothing special - better oils out there for the money.
Old Jul 28, 2004 | 03:01 PM
B HATCH's Avatar
I never knew that................
I feel like this is the most important information I have learned in a long time.
EDIT: Spelling corrected
Modified by B HATCH at 11:17 PM 7/28/2004
Old Jul 28, 2004 | 05:41 PM
Grumpy's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B HATCH &raquo;</TD></TR><TR><TD CLASS="quote">i never knew that................
I feel like this is the most importat information i have leared in a long time.</TD></TR></TABLE>
Besides spelling
Old Jul 28, 2004 | 05:56 PM
myke's Avatar
From: South LA...107th and fig to be exact...for the foo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">There was just a topic on tranny fluid..... https://honda-tech.com/zerothread?id=931423
you must have a clutch type diff running that oil. right? i hope you do...
just use oem tranny fluid works me
Old Jul 28, 2004 | 05:59 PM
.RJ's Avatar
.RJ
Default Re: YES I SEARCHED - 2 quick ITR TRanny Questions - Racing oriendted (myke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myke &raquo;</TD></TR><TR><TD CLASS="quote">you must have a clutch type diff running that oil. right? i hope you do...</TD></TR></TABLE>
Why do you say that?
Motul sells "Gear FF" for cars with a clutch type diff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">just use oem tranny fluid works me</TD></TR></TABLE>
For the street, sure... Honda mtf is shear happy. I tried it in my car for several track events - at first it felt great but after one weekend it felt notchy and if I left it in 2 weekends it would grind in 2nd/3rd gear once it got hot.
new http://theoildrop.server101.co...00000
brand new the viscosity is 11.26 which is halfway up the 30wt scale.
used http://theoildrop.server101.co...00562
after approx. 22,000 miles the viscosity is 6.63cst@100C which is a low 20wt.
Old Jul 28, 2004 | 06:03 PM
myke's Avatar
funny we have been using oem fluid on Andy Hopes trans and its been running perfect...guess its different for everybody.
i was under the idea that only clutch type diffs needed thick fluids...is this true?
Old Jul 28, 2004 | 06:08 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myke &raquo;</TD></TR><TR><TD CLASS="quote">funny we have been using oem fluid on Andy Hopes trans and its been running perfect...guess its different for everybody.
i was under the idea that only clutch type diffs needed thick fluids...is this true?</TD></TR></TABLE>
some people just think they can feel a difference....personally i don't know how rj would even know if his tranny is getting hot....he hasn't touched a rumble strip ever....nor is he on the gas until track out....so.....i think the fluid feel in his "notchy tranny" is just the rocks floating in his head!!
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myke &raquo;</TD></TR><TR><TD CLASS="quote">funny we have been using oem fluid on Andy Hopes trans and its been running perfect...guess its different for everybody.</TD></TR></TABLE>
How often are you changing it?
I would not use the OEM MTF in a track/race car same as I would not use the OEM brake fluid or engine oil. It may work for some, but it is shearing and breaking down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i was under the idea that only clutch type diffs needed thick fluids...is this true?</TD></TR></TABLE>
Has nothing to do with the vicsosity.
I will have a temp strip on my case for VIR to see how hot it is getting in there.
Old Jul 28, 2004 | 06:14 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">some people just think they can feel a difference....personally i don't know how rj would even know if his tranny is getting hot....he hasn't touched a rumble strip ever....nor is he on the gas until track out....so.....i think the fluid feel in his "notchy tranny" is just the rocks floating in his head!!</TD></TR></TABLE>
*shrug*
Take it for what you will, I know what my experience has been but I am not the original owner of the car - although I have no reason to believe it was abused by the previous owner.
If I left the fluid in longer than one weekend it would grind pretty bad if i tried to go into 2nd and sometimes 3rd gear (when hot, not on the street ever), and the problem went away when I switched to a better fluid, and I am running longer drain intervals as well on it - and saving money in the end. Unless of course I was just imagining that one too.
Old Jul 28, 2004 | 06:16 PM
myke's Avatar
I will have a temp strip on my case for VIR to see how hot it is getting in there.</TD></TR></TABLE>
ill put one on Andys car for mid-ohio and we can compare the temps
chad's Avatar
Moderator
i have had the same MOTOR OIL (tranny fluid) in since febuary VIR enduro in the race car.....
no problems....
Old Jul 28, 2004 | 08:08 PM
Evan55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">....nor is he on the gas until track out....so.....</TD></TR></TABLE>
which is still better than parked and smoking at track out....
Old Jul 29, 2004 | 04:01 AM
Dancing is Forbidden's Avatar
Default Re: YES I SEARCHED - 2 quick ITR TRanny Questions - Racing oriendted (elgorey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elgorey &raquo;</TD></TR><TR><TD CLASS="quote">which is still better than parked and smoking at track out....</TD></TR></TABLE>
nissanjon
21
May 19, 2005 03:49 PM
AlekSir
Mar 22, 2005 07:20 AM
TypeRuz
Oct 28, 2003 04:58 PM
EF-9SiR
10
Nov 3, 2002 07:57 AM
CW_97_ITR
Jun 17, 2002 10:48 AM
