92 Honda Accord Turn Signal(Blinkers) going Out
Hi ,
My 92 honda accord Turn signals are going out . The left turn signal(blinkers) is blinking fast compared to the right turn signal. After 1 day/ 2 days all the blinker goes out with the fuse blown out.
I will highly appreciate any help.
Thanks
Nirod
Thanks
Nirod
If one side was blinking faster that means either the front or rear bulb was burnt out....
now you are saying they're all burnt out or were you asking if they will burn out?
<-- Kinda confused
<-- Kinda confused
First time I noticed the fuse and as well one bulb( font left) is blown out . I replaced the bulb and the fuse. It started working. But still the left turn signal was runnig fast than the right one. It worked like that for two days. Then all the turn sinals ( left & right) stopped working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nrsahoo »</TD></TR><TR><TD CLASS="quote">It started working. But still the left turn signal was runnig fast than the right one. </TD></TR></TABLE>
If it started working was it still blinking fast?
<--- thinks maybe you didnt change the right bulb?
if it was still running fast then i dont think you changed the right bulb, do you still have the bulb that you replaced?
It should appear burnt inside (dark greyish color)
cancoo
Mar 14, 2008 08:03 PM
