where to buy prep stuff?
Old Jul 28, 2004 | 09:51 AM
ThisLittleSleepeR's Avatar
Default where to buy prep stuff?
where whould i buy all the things i need to prep my car for paint? and can anyone give any tips. i have a compressor so what kind of sander do i use, or where can i rent one? i also searched but there are diffrent opinions. also what is a block sander thanks
Old Jul 28, 2004 | 10:14 AM
Filthy Focker!'s Avatar
Default Re: where to buy prep stuff? (ThisLittleSleepeR)
You want to paint your car yourself....
First, i hope you have a garage to paint it in.
Also, hope you got at least some fans to exhaust the fumes?
First, sand down all the chips and rough stuff off you car. You can use a electric vibrating sander if you wish.
Then prime the areas where you went through the paint. If you see the metal, apply some zinc phosphate primer first.
Then sand the car with at least some 400 grit (500 prefered). Sand until all the shine has been removed. Remember, always sand in the same direction.
Then apply 2 coats of base and top off with a good 3 coats of clear.
Most importantly, make sure your car is washed, degreased and free of dust. Also, make sure you respect the flashtime of your particular paint system to avoid a **** job. Apply thin wet coats and you should be fine.
Now you can get paint supplies from a good automotive parts store. Make sure you buy a complete system, from primer to clear from one paint maker. This way, you avoid compatibility issues.
Get yourself a good respirator. Because that stuff is nasty. Especially if you are not going to use an HVLP system.
Lastly, the key to a good paint job is the way your gun will be adjusted. So if you are using a conventional siphon feed gun, proper atomization of the paint is crucial.
good luck
fs
Old Jul 28, 2004 | 10:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: where to buy prep stuff? (filthy_shovel)
After you spray the primer, spray a very light dusting of black spraypaint over it. Then when you block sand it (you can use 400 wrapped around a paint stick), you will know where any low spots are if there is any black still showing.
^^^ little trick my friend who painted my car taught me.
Old Jul 28, 2004 | 04:58 PM
thanks so far, im not planing on painting the car myself? although i thought of it. i just want to prep myself since i have nothing else to do till school starts up again.
Old Jul 28, 2004 | 05:04 PM
swifty4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">Remember, always sand in the same direction. </TD></TR></TABLE>
Just one direction, or back and forth? -&gt; -&gt; or -&gt; &lt;- ?
Old Jul 29, 2004 | 08:40 AM
Default Re: where to buy prep stuff? (swifty4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swifty4u &raquo;</TD></TR><TR><TD CLASS="quote">
Just one direction, or back and forth? -&gt; -&gt; or -&gt; &lt;- ? </TD></TR></TABLE>
also like to know
matmcg
Paint and Body
18
Mar 23, 2008 09:28 AM
kniob
Jan 17, 2006 07:56 PM
ochsy03
Dec 19, 2004 04:11 PM
ITR_1211
Dec 23, 2003 04:02 PM
GroundZer0
Sep 9, 2003 07:57 AM
