putting together a turbo need help please.....
just getting into force induction. i have a 2001 non-sh prelude and putting together a turbo for her. bought an fmax manifold with a t3/t4b turbo (turbonectics), rc440cc injectors, apexi avc-r, apexi power fc, tial 38mm wastegate, and a blitz intercooler. i am missing a downpipe, oil feed line, return line, bov, and charge pipes. where can i get the oil lines from and wat fittings would they be. also where can i find a downpipe (can it be custom made)? and the charge pipe wat bend do i need to make my own. i have a welder. any help would be appreciated.
thanks in advance
liem
thanks in advance
liem
for the oil lines, contact Stan, his user name on Honda-Tech here is Flamenco-T and his website is http://fast-turbo.com
For the downpipe and charge pipes, I dont know if he has a vehicle to test fit on for ludes, but try contacting Project DC2 on ht here
thank you. was also wondering if anyone here on h-t that does intercooler piping. and how much that they would charge to make one.
Modified by boosted_lude at 11:13 AM 7/28/2004
Just make your own. I just purchased mine from jc whitney. Email me and i can send you a "how to build a turbo honda" acrobat file. It tells you the how to's and and what pipes you need. I spent 70 bucks for mine. Some pre fab ones go for 400.
For the oil lines, contact flamenco-t.
Good Luck.
Good Luck.
For the piping, from JC Whit, here are the part numbers:
(You will need to order two of these) ZX813031U 180 Degree Mandrel-Bent Aluminized Tubing, (A/B)=12", (C)=5", ID=2-3/8", OD=2-1/2" Each 13.95
ZX812953P 90 Degree Mandrel-Bent Aluminized Tubing, (A/B)=10", (C)=5", ID=2-3/8", OD=2-1/2" Each 9.95
ZX813035N 180 Degree Mandrel-Bent Aluminized Tubing, (A/B)=24", (C)=5", ID=2-3/8", OD=2-1/2" Each 22.95
Ri5e
Aug 26, 2004 03:31 PM
stylinlude
Jul 28, 2004 05:48 AM
OG SHG_EM1
Mar 28, 2004 09:10 PM
