Volume output increases with the gas and decreases when I brake =/
Old Jul 28, 2004 | 08:32 AM
PapaPark's Avatar
HT White Ops
Default Volume output increases with the gas and decreases when I brake =/
I installed a pioneer head unit... kept the factory speakers
installed 2 subs with an amp
everything was fine until I realized the volume output would get louder as I pushed the gas and got softer when I pushed the brake. The actual volume level on the head unit would remain at the number I put it on...
anyone ever run into this problem?
Old Jul 28, 2004 | 08:51 AM
spark plugs.
Guest
Posts: n/a
Default Re: Volume output increases with the gas and decreases when I brake =/ (PapaPark)
prolly something to do with power. does the deck get brighter?
Old Jul 28, 2004 | 09:03 AM
PapaPark's Avatar
HT White Ops
Default Re: Volume output increases with the gas and decreases when I brake =/ (spark plugs.)
Yes it does.... I was thinking power myself but I don't why.
I used a thin wire from head unit to the amp... so I'm thinking that may be it... but I thought the power wire was just enough to get the amp started(turned on).. I didn't know it was a continous flow of power....
Old Jul 28, 2004 | 09:45 AM
spark plugs.
Guest
Posts: n/a
it could be your alternator. the v.r. could be going bad. have you checked if your head light brightens when you give it throttle?
Old Jul 28, 2004 | 10:06 AM
PapaPark's Avatar
HT White Ops
it does not.... plus it didn't do it with the factory radio
Old Jul 28, 2004 | 10:20 AM
ipleadthe5th's Avatar
Photoshop Guru
Sounds like low volts from battery or problem with alternator. Get a volt meter and see what the voltage is at the back of the radio with the car turned on a the car cranked.
Old Jul 28, 2004 | 03:14 PM
jdmotorsports's Avatar
Default Re: Volume output increases with the gas and decreases when I brake =/ (ipleadthe5th)
go through your settings. you probably have the a.s.l. turned on. it changes the volume depending on how your driving. turn it off and the volume will remain true. i assume you have a newer pioneer head.
Old Jul 28, 2004 | 04:23 PM
bassisliffe's Avatar
Default Re: Volume output increases with the gas and decreases when I brake =/ (jdmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">go through your settings. you probably have the a.s.l. turned on. it changes the volume depending on how your driving. turn it off and the volume will remain true. i assume you have a newer pioneer head. </TD></TR></TABLE>
i gotta get that ****!!!!!!!
Old Jul 29, 2004 | 09:09 PM
AoiGSR's Avatar
25 Year Member
jdmotorsports might be right. from the sound of it, I think it's a.s.l. too.
-aoib0t, who doesn't like a.s.l
Old Jul 30, 2004 | 12:45 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Volume output increases with the gas and decreases when I brake =/ (AoiGSR)
Doesn't the asl change the volume number on the deck though? I have never actually turned it on, on my Pioneer.
Old Jul 30, 2004 | 02:07 PM
AoiGSR's Avatar
25 Year Member
Default Re: Volume output increases with the gas and decreases when I brake =/ (rochesterricer)
nope
-aoib0t, who knows :B
Old Jul 30, 2004 | 03:30 PM
teamxtant's Avatar
At first I would have said its the A.S.L. However, he said his deck get brighter also. The A.S.L. does not brighten your deck, only increases the volume to compensate for engine noise as the RPMs rise. As far as the lights getting brighter, I would definitely check your voltage regulator. I had a similar problem with a customer's car a few years back. The car's voltage would rise to 19.2V when I reved the engine and back down to 14.2V at idle. You may have your A.S.L turned on and a problem with your alternator or wiring.
Old Jul 30, 2004 | 05:37 PM
incubus's Avatar
Default Re: Volume output increases with the gas and decreases when I brake =/ (teamxtant)
most likely the asl like they said.
Old Jul 30, 2004 | 06:08 PM
7808's Avatar
Default Re: Volume output increases with the gas and decreases when I brake =/ (incubus)
if your lights get brighter, its got to be your voltage regulator. check your amp wiring too.
Old Jul 30, 2004 | 09:50 PM
harlen's Avatar
Default Re: Volume output increases with the gas and decreases when I brake =/ (fuctup)
i think you need a capacitor :]
dth0ng69
Audio / Security / Video
Aug 4, 2008 05:03 AM
spfreak
Sep 26, 2004 08:18 PM
Questioner
Aug 23, 2003 07:41 PM
97accordse
Mar 6, 2002 12:39 PM
97accordse
Mar 4, 2002 12:34 PM
