WHAT OIL WEIGHT TO USE ?
Old Jul 28, 2004 | 07:15 AM
cmdr430's Avatar
Default WHAT OIL WEIGHT TO USE ?
searched, didnt see anything
what oil weight should i use on my daily driver 89 civic std hatchcrap,
it has 225,xxx miles on it
thanks for any input......
Old Jul 28, 2004 | 07:17 AM
manson's Avatar
Default Re: WHAT OIL WEIGHT TO USE ? (cmdr430)
5w 30
Honda recommended
Old Jul 28, 2004 | 07:33 AM
kaoss_11's Avatar
B A N N E D
Default Re: WHAT OIL WEIGHT TO USE ? (manson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manson &raquo;</TD></TR><TR><TD CLASS="quote">5w 30
Honda recommended</TD></TR></TABLE>
correct
Old Jul 28, 2004 | 07:34 AM
cmdr430's Avatar
so you dont think that because it has 225 thousand.... miles on it i should change the oil weight?
Old Jul 28, 2004 | 07:39 AM
gutted-dx's Avatar
In the summer i would run 20w 50, since it's thicker you get a better seal on your rings, and it won't leak through valve seats and burn as easily, I would get thicker. Until cold weather came around.
Thats what i run in my std hb, and EG coupe.
Old Jul 28, 2004 | 08:04 AM
DXDOHCVTEC's Avatar
Default Re: (gutted-dx)
haha 5 30 honda recomended
I dont think they would recomend that with a quarter million miles on it
20-50 year round would be a good idea
Old Jul 28, 2004 | 09:03 AM
gutted-dx's Avatar
5w 30 is recommended most likley for a brand new engine.
Old Jul 28, 2004 | 09:10 AM
APEX CRX's Avatar
With that many miles I'd go 20w50
Old Jul 28, 2004 | 09:15 AM
crxgator's Avatar
Default Re: WHAT OIL WEIGHT TO USE ? (APEX CRX)
10w30 for you if your burning oil, are you?
i still use 5w30 on my 130k mile engine...
Old Jul 28, 2004 | 09:17 AM
gutted-dx's Avatar
This engine is 225,xxx
Old Jul 28, 2004 | 09:57 AM
Two_K Si's Avatar
Use whatever oil you have been using. If it isn't broke, don't fix it.
Old Jul 28, 2004 | 10:05 AM
green91's Avatar
i always run 10w30 or 10w40 but i think my valve seals leak a little with it
Old Jul 28, 2004 | 10:09 AM
wtsexton's Avatar
I run 10w30 redline.
Old Jul 28, 2004 | 04:49 PM
gutted-dx's Avatar
The higher the miles the thicker the oil you want. Period
Old Jul 28, 2004 | 04:56 PM
Tyson's Avatar
10w40 for summer or any moderately warm place. 5w30 is for winter and cold starts. id rather have protection when i get my engine running hot. &lt;----- period
Old Jul 28, 2004 | 09:53 PM
alexdog69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted-dx &raquo;</TD></TR><TR><TD CLASS="quote">The higher the miles the thicker the oil you want. Period</TD></TR></TABLE>
Rings usually get pretty worn with 200+k miles.... thicker oil can help with this...
The 5w30 recommendation from Honda is based on fuel efficiency anyway...
Old Jul 28, 2004 | 10:05 PM
Synth124's Avatar
Default Re: (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">Use whatever oil you have been using. If it isn't broke, don't fix it.</TD></TR></TABLE>
then when it does brake because of your bearings failing, you wish you did fix it. Sorry not to be a dick.
Remember man, just keep check of your oil and treat the car as good as possible and you should luck out. My bearings failed at 245k
817boy
11
Sep 16, 2008 09:11 PM
RSX_S
May 7, 2008 11:58 PM
hondacrx2
Jan 17, 2008 04:40 AM
rolledthatho
17
Oct 15, 2005 08:08 AM
JimmyAtlantis
Feb 21, 2004 08:10 AM
