fuse location when relocating the battery to the trunk
When relocating the battery to the trunk, on the hot cable, should I place a fuse in the engine compartment, trunk, or both?
Thanks.
Thanks.
Nope. If any part of the wire shorts, it will blow the one near the battery. The reason you put it close to the battery is because you have less chance of that short piece of cable shorting out.
