Mugen B-Pipe.
I'm not sure if it's called a B-pipe or not, but it's the part before the axle-back section and after the Cat.
Anyways, I read around the forum and I saw someone mention that the Mugen Twin-Loop Catback has 2" piping before the Resonator and 2.5" after. Is this true? If so, would it be better to replace it with a T1R B-Pipe (2.5"), or would it be pointless? I think Mugen would have made it that way for a reason... Or not.
Anyways, Thanks.
- Girl.
Anyways, Thanks.
- Girl.
what muffler are you going to use, if its also 2.25 then anything 2.25 would be fine, but if you have a 2.5 muffler then get something that matches other flow of exhaust gas will keep moving
I had this system before and I think it will work well with a internally stock motor or with mild cams.
Apparently from what I understand this was done to increase the velocity of the exhaust. I'm sure SMSP could school us all on whether or not this is really effective....but apparently it's a rather popular setup on some Turbo Porsches I've seen...stepping up from smaller piping to some monster pipes near the tail end.
[subliminal]Now buy a sparco driver package[/subliminal]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Girl »</TD></TR><TR><TD CLASS="quote">the Mugen Twin-Loop Catback has 2" piping before the Resonator and 2.5" after. Is this true?</TD></TR></TABLE>
yep...mine is like that...maybe it's done like that to fit the usdm cat?
i have mugen twin loop with t1r b pipe..
i like it but i dont know if i can tell the differeance by that much.
it got little louder than stock mugen b pipe but nothing too crazy.
i think mugen b pipe is good enough i had t1r b pipe and spoon n1 system before and only reason i replaced my mugen with t1r is i had it laying around.
when i compared two t1r had bigger piping so i just did it.
i`d say spend the money on something else.
it:s still couple bills.. get a hid or something with that.
