quick question?
Old Jul 27, 2004 | 11:16 PM
ek4hatch's Avatar
Default quick question?
those the b series axles are the same?
Old Jul 27, 2004 | 11:21 PM
wisjdmhonda's Avatar
Default Re: quick question? (ek4hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4hatch &raquo;</TD></TR><TR><TD CLASS="quote">those the b series axles are the same?</TD></TR></TABLE>
No, some are for cars with abs. anybody else know anyother things that are dif?
Old Jul 27, 2004 | 11:25 PM
ABK's Avatar
ABK
Default Re: quick question? (wisjdmhonda)
I think first gen tegs had different b series axles but I might be wrong.
Old Jul 27, 2004 | 11:26 PM
Kyles ej1's Avatar
not sure but ones but i think one is longer, i think the ls ones r longer not 2 sure
Old Jul 27, 2004 | 11:27 PM
ek4hatch's Avatar
well cuzz i got a 96 ek hb with a 2001 gsr motor and i need a left axle so i was wondering if the 99-00 si will work ??
Old Jul 27, 2004 | 11:46 PM
IVI's Avatar
IVI
you have to check.
look under your car and see if you need the half shaft or not.
the 99 civic si has a shaft which is twice the length that you might need. im trying to think if it was the drivers side or passenger side im referring to.
anyway, just jack up your car get a visual and then goto pepboys or whatever store and just have a look at the axle before you buy it.
the only diffrnece between an abs axle or a non abs axle is the tiny rivets on the end for the abs sensor.
an abs axle will work even if you dont have abs.
Old Jul 27, 2004 | 11:50 PM
ek4hatch's Avatar
Default Re: quick question? (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">you have to check.
it's the driver side!!
Old Jul 28, 2004 | 12:00 AM
IVI's Avatar
IVI
it's the driver side!!</TD></TR></TABLE>
no im trying to visualize what side im talking about. i cant remember. i think yah its the drivers side because the tranny is more over to the passenger side.
civintegra
14
Jul 22, 2011 10:21 PM
EF-ingB16
Jan 8, 2011 04:22 PM
B16b-EJ8
Jan 21, 2008 03:02 AM
benchmade
Northern California (Sales)
Jan 8, 2008 09:44 PM
posHonda
Apr 16, 2007 06:46 PM
