All around disc brakes on DX
I was looking into converting my rear drum brakes into disc brakes. I was just wondering what parts I would need to do this and if it was simple enough for me to do or if I should take it to a shop?
Thanks for the help!!
You need the full spindle, traling arm and disc off of a SI or a integra (94-01) You also need the brake lines and the e-brake cable. You can use your LCA's and your camber rods that bolt to the top of the trailing arm/spindle.
wow, havent we done this thread a lot before?
99-00 CIvic Si rear trailing arm assembly
99-00 CIvic Si e-brake cable
Get new brake lines (99-00 Si, but check a pepboys first or somethin)
99-00 CIvic SI proportioning valve 4040
99-00 Civic Si master cylinder
These are the parts. Also, check the rotors (reccomend new ones and new pads). Get some DOT3 brake fluid, youll have to bleed the lines.
IF you can't get 99-00 CIvic Si rear trailing arms, those from a 97 Del Sol Si will work. those from a 94 Integra will work, but you'll need the integra e-brake cable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX »</TD></TR><TR><TD CLASS="quote">wow, havent we done this thread a lot before?
IF you can't get 99-00 CIvic Si rear trailing arms, those from a 97 Del Sol Si will work. those from a 94 Integra will work, but you'll need the integra e-brake cable.</TD></TR></TABLE>
He can't get an 99-00 si proportioning valve because of the abs that they have...you need to get one that is for 95 civic si with non abs....you can go to http://www.acuraautomotiveparts.org/ its like 125 bucks
watisjdm
Aug 31, 2009 07:02 AM
