My Steering wheel shakes while accelerating...HELP
Old Jul 27, 2004 | 10:16 PM
H22Psi's Avatar
Default My Steering wheel shakes while accelerating...HELP
Hi, i'm new to this board and have a question. I have the 2000 prelude and my steering wheel will shake really bad when i accelerate. It doesn't shake if i put it into neutrul and coast. I thought it was my tires at first but TireWorld checked out my tires and said they were balance, I changed out my passanger side front axle, and it still shakes. Does anyone know of this problem? or have any idea what the heck is going on? Please help me...thanks for any replys.
Old Jul 27, 2004 | 11:42 PM
Slipknt777's Avatar
Default Re: My Steering wheel shakes while accelerating...HELP (H22Psi)
alignment, loose lugs...those have cause shaking for me in the past. maybe its the rack and pinion...not sure if that would cause vibrations...just know its part of the steering.
Old Jul 27, 2004 | 11:49 PM
damonk's Avatar
mine shakes a little but i just put that together with the front wheel drive. maybe its a combo
Old Jul 28, 2004 | 08:45 PM
H22Psi's Avatar
Default Re: My Steering wheel shakes while accelerating...HELP (Slipknt777)
My and a friend checked everything possible. He did mention that the rack and pinion might be lose. Is there a way to check for that? We also notice when we rock the wheel from side to side it makes a noise (like there's not enough fluid). Is there a way to check for the steering wheel fluid? seeing if it goes through all the hose? Does the power steering pump have to have a certain pressure? Because we don't think its holding the pressure to force the fluid through. Please help. Thanks
95C0upe
18
Oct 28, 2008 06:30 PM
JoKarma
Sep 20, 2005 10:56 AM
Essence of Chicken
Nov 13, 2003 09:21 PM
cr-x si
Sep 12, 2002 06:43 AM
cohenr
Aug 26, 2002 06:52 PM
