Installing pistons with block in the car?
Old Jul 27, 2004 | 10:08 PM
Ti3d in's Avatar
Default Installing pistons with block in the car?
I plan on dropping in some pistons when I do the 120K tuneup, but I'm skeptical about pulling the block. I can't have my car down since it is my daily driver, so that's why I'm comtemplating to pulling the head and oil pan, and dropping in the pistons from there. I know a lot of people say this isn't the "right" way to build a motor, but I think it would be ok as long as I honed the walls. I think Omniman did the same thing in his 200whp project if that means anything. Any input from people who have done this? It would help me out greatly.
Old Jul 27, 2004 | 10:12 PM
jdmsijdm's Avatar
Default Re: Installing pistons with block in the car? (Ti3d in)
thats how mine were done, by a very reputable shop that posts on this board often. havent had any probems at all. they did it the same way.
Old Jul 27, 2004 | 10:18 PM
Ti3d in's Avatar
Default Re: Installing pistons with block in the car? (jdmsijdm)
Did you use OEM or aftermarket pistons?
Old Jul 27, 2004 | 11:27 PM
Kendall's Avatar
One of my very good friends built his engine this way, runs great. Another of my friends is in the process of rebuilding his engine this way.
Old Jul 27, 2004 | 11:36 PM
Ti3d in's Avatar
Default Re: (Kendall)
How would I check rod bearing clearances though?
Old Jul 27, 2004 | 11:39 PM
Supernatural's Avatar
Default Re: (Ti3d in)
plastigue works even if you are lookin up at it
if you are building it this way....then you are assuming there is nothing wrong with the crank......so reuse bearings or use new same color bearings.....and torque it to spec
Old Jul 27, 2004 | 11:52 PM
Combustion Contraption's Avatar
with all the work to take the head off and drop the oil pan, why not just pull the whole thing.
Old Jul 27, 2004 | 11:53 PM
Ti3d in's Avatar
Default Re: (SUPERNATURAL)
It's ok to reuse bearings? I'd rather buy new same color bearings, but then I might be screwed if the dealership doesn't have them, and my car will be down. There's no other way to know what color rod bearings I have other than checking the crank itself right?
Old Jul 27, 2004 | 11:55 PM
Ti3d in's Avatar
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">with all the work to take the head off and drop the oil pan, why not just pull the whole thing.</TD></TR></TABLE>
I'm trying to do this in a weekend.
Old Jul 28, 2004 | 12:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">It's ok to reuse bearings? I'd rather buy new same color bearings, but then I might be screwed if the dealership doesn't have them, and my car will be down. There's no other way to know what color rod bearings I have other than checking the crank itself right?</TD></TR></TABLE>
usually motor rebuilds require more time and attention than just one weekend .....your gonna need to know the bearing codes ahead of time becauase usually thats a special order part....also working on weekends leaves you assed out if you need something and the dealership is closed.....as far as im aware you can only find out by looking at the crank....your car will be down at least 3-4 days for this.....sorry to break it to you
Old Jul 28, 2004 | 01:26 AM
GOLDBERG's Avatar
true for him since hes at 120k...but if your at like say 1k miles on a fresh build...just rings never seated...u could save a hundred bucksalmost..no need for a new HG
Old Jul 28, 2004 | 01:46 AM
um, once you pull the head, you need a new headgasket.
91integraLSVTEC
Engine Machining & Assembly
Mar 17, 2018 02:42 PM
slob20ef
Aug 29, 2009 06:18 PM
Touch
Oct 18, 2005 10:47 AM
Tropicana18T
Feb 23, 2004 03:40 PM
743power
Mar 2, 2002 03:16 PM
