what does upgraded/aftermarket LCA do?
I would like this too. I know theres some that are adjustible so it works good when you go for a alignment, also you might need to upgrade if you want a sway bar.
Other then that i see no reason
well think of it this way, if you have an EG your car is at least 12 years old, thats 12 years of road life on those LCA's If you've ever changed your own suspension back there, you know of the bitch bolt. With New LCA's that problem is gone, cause you'll have new bolts and LCA's back there, no more rusted bolts, no more snapped heads, no more late night raw knuckle curse fests!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxBurnoutKing »</TD></TR><TR><TD CLASS="quote">well think of it this way, if you have an EG your car is at least 12 years old, thats 12 years of road life on those LCA's If you've ever changed your own suspension back there, you know of the bitch bolt. With New LCA's that problem is gone, cause you'll have new bolts and LCA's back there, no more rusted bolts, no more snapped heads, no more late night raw knuckle curse fests!</TD></TR></TABLE>
You said it.
You said it.
BDogggUT34
Aug 31, 2007 12:34 PM
