Picture Request. B series EF with turbo
Old Jul 27, 2004 | 08:27 PM
lococoin's Avatar
Default Picture Request. B series EF with turbo
Im looking for some idea of how things are run for when i do my b18 turbo into a 90 hatch.
Any pictures would be appreciated.
Thanks
Old Jul 27, 2004 | 09:01 PM
89SiR's Avatar
Default Re: Picture Request. B series EF with turbo (lococoin)
Heres some older pics of mine, I have done some changes to the piping now and have added a CO2 sprayer kit from DEI.
Old Jul 27, 2004 | 09:47 PM
ef nine's Avatar
damm look nice how many hp is that?
Old Jul 27, 2004 | 10:23 PM
Volkrays's Avatar
Old Jul 27, 2004 | 10:26 PM
speeddave's Avatar
Default Re: Picture Request. B series EF with turbo (Volkrays)
looks good guys! post more pics... plus tech info too keep this going
Old Jul 27, 2004 | 10:27 PM
hondatahatch's Avatar
Nice pics
Old Jul 27, 2004 | 11:08 PM
lococoin's Avatar
Default Re: Picture Request. B series EF with turbo (hondatahatch)
volkrays,
Do you have a shot looking straight down from above the engine. id like to see where the turbo sits
thanks
Old Jul 27, 2004 | 11:11 PM
lococoin's Avatar
id also like to know what turbo, manifold, wastegate, and engine mounts you running to still fit a fullsized rad in your car.
thanks
Old Jul 27, 2004 | 11:31 PM
Volkrays's Avatar
More pics, click below:
http://www.villagephotos.com/p...61698
Old Jul 28, 2004 | 07:31 AM
Charlie Moua's Avatar
Default Re: Picture Request. B series EF with turbo (89SiR)
damn your car is badd *** yo.
what manifold is that? MPF?
Old Jul 28, 2004 | 11:22 PM
SiR Kid's Avatar
New User
I've posted mine a meelion times... Sorry, but these threads keep popping up.
I've sold the WAIC, and I am getting a midsized FMIC from Precision TE.
Here's what it looks like in full "Sleeper Mode"
On the front there is my reservoir, some lines, and heat exchanger for the WAIC.
And on to the goods...
Tial 35mm wastegate, Custom wastegate elbow, Custom 3" DP, Thermal 3" exhaust, Precision SC34 60ar 57trim/ .63 stage 3 turbo, Spearco WAIC model 252, Custom piping, InlinePro Manifold, GReddy BOV, Z-Dyne Gold ECU, GSR cams, Endyne Pistons, Eagle rods, ITR IM, 64mm JG TB, 3 bar map, GReddy TT, GReddy Profec B... and on and on and on.
What we had to build to clear the JimFab bars:
My most recent Dyno... The WAIC was running low on efficiency, thus the move to FMIC. I'm looking for 300-320whp at the same boost level as before (15 psi) with this upgrade.
Old Jul 29, 2004 | 02:46 AM
c jackson's Avatar
threes
Default Re: Picture Request. B series EF with turbo (SiR Kid)
Old Jul 29, 2004 | 04:16 AM
crx_88_si's Avatar
how bout two?
ls/vtec twin turbo
*not my car* AbaZ's
285whp w/ 191 wtq stock bottom end. (actually had ITR pistons, yes, high compression)
Old Jul 29, 2004 | 10:41 AM
lococoin's Avatar
Default Re: (crx_88_si)
Excellent pictures. Thanks for the ideas
Old Jul 29, 2004 | 11:39 AM
sloweh3's Avatar
Default Re: (lococoin)
I have a question for all of your w/ b-series swaps w/ turbo in an EF. I just did my b18a swap 2 months ago, and I got some generic uerothane mounts from a friend. Well, I'm going turbo here in the winter, and my stock manifold is touching the front crossmember. Do you have to get a new rear mount in order to turbo a b-series?
Old Jul 29, 2004 | 11:43 AM
Rywire's Avatar
Default Re: (H82BLGL)
If your stock 4-2-1 header is touching the front x-member, sounds like those mounts position the engine too far foward, especially if you are going turbo.
Old Jul 29, 2004 | 12:09 PM
Nocturnal_Lude's Avatar
Default Re: (droppedcrxsi)
Do a search on ef b series mounts...I have seen numerous write ups on here with people describing how each different mount makes ur motor sit. hth
lococoin's Avatar
what motor mounts are recommended. I picked up a set of these
http://www.yonaka.com/motormounts.htm
the price was right so i couldnt go wrong.
Old Jul 29, 2004 | 12:27 PM
sloweh3's Avatar
Those look like the ones I got
Old Jul 29, 2004 | 01:29 PM
HondaPartsHero's Avatar
Technical Hero
4 years ago
Old Jul 29, 2004 | 01:36 PM
chads's Avatar
Default Re: (yebabee)
nice ef's
Old Jul 31, 2004 | 02:58 PM
sloweh3's Avatar
How'd that thing run? And was it built?
ChronoEF
Jun 8, 2006 10:35 AM
Jr_Gizzy
Mar 19, 2004 03:35 PM
CWBETB
13
Apr 8, 2002 06:12 PM
