Need Help...Si Distributor
Hey i'm doing a dpfi to mpfi swap. I have one good question. Where the Si distributor wires go into the DX harness. There are about 7 wires. 2 of them go into the C1,C2 pins. The other one is all the way on the right and that is white so i thought that it didn't belong to anything. However there are 4 that make a square on the left. Wires look like this:
peach blue/orange Blue/yellow White
white blue/yellow Blue/green
Its set up sorta like that if u look at the wires. However when hooking up the wires i can connect the (blue/orange), (blue/yellow), (blue/green), and (blue/yellow) to various wires in the DX harness. However, the peach and white are suppose to be another green/blue and like a white/orange. Do i have the wrong distributor or whats going on?? Hope someone can help me. Thanks!
the only difference between dx and si dizzy are 2 extra wires on the si. Blue/Yellow and Blue/Green. Run 2 extra wires through the firewall and to those wires. Double check, but they should hook up to c1 and c2 i believe.
