Cut Bumpstops on neuspeed sports
Old Jul 27, 2004 | 04:45 PM
gimpykid12's Avatar
Default Cut Bumpstops on neuspeed sports
I searched this but cant find a direct answer, I just purchased some Neuspeed Sports and Koni Reds for my 96. The instructions say dont cut the bumpstops, however, I've read many posts of people agreeing and disagreeing about this, I'd like to do it right the first time so which is it?
Old Jul 27, 2004 | 05:52 PM
IVI's Avatar
IVI
Default Re: Cut Bumpstops on neuspeed sports (gimpykid12)
dont cut them
dismantle stock shock, and put parts that you took off stock onto new one and reassamble.
very simple.
Old Jul 27, 2004 | 05:55 PM
purplegsr's Avatar
Default Re: Cut Bumpstops on neuspeed sports (IVI)
Another debate rages on, with Neuspeed Sports, I would encourage you to cut them. Basically, it will allow for more suspension travel if you cut about an inch off of the bottom of each bumpstop. Your ride may be more bouncy if you leave the bumpstops that length, and I think the Konis will be able to handle the extra travel. If you don't cut them, you may want to make sure the Konis are set to a firm setting, I think the Reds are three way adjustable while off of the car by pushing on the piston and turning right.
Old Jul 27, 2004 | 07:09 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Cut Bumpstops on neuspeed sports (purplegsr)
Follow the directions from Neuspeed. I know on my Eibach Pro Kits the directions say to cut the front bump stops only.
Old Jul 27, 2004 | 07:44 PM
boostedsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">Another debate rages on, with Neuspeed Sports, I would encourage you to cut them. Basically, it will allow for more suspension travel if you cut about an inch off of the bottom of each bumpstop. Your ride may be more bouncy if you leave the bumpstops that length.</TD></TR></TABLE>
I agree
Old Jul 27, 2004 | 09:22 PM
-faded-'s Avatar
Default Re: Cut Bumpstops on neuspeed sports (boostedsol)
cut em. i have mine cut on my 01 teg and its fine
herrgolf
39
Aug 24, 2017 10:30 PM
kkim
Suspension & Brakes
Jul 1, 2005 07:42 AM
anekin007
Suspension & Brakes
15
Apr 20, 2005 04:34 AM
DA_TEG
May 2, 2004 01:29 PM
raceACCORDingly
Jan 23, 2002 06:56 PM
