crx brake lockup problem
Old Jul 27, 2004 | 04:12 PM
J-balint-k's Avatar
Default crx brake lockup problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
please help me,
ok i arrived home from work today and when i decided to leave home a few momments later i noticed a screech coming from my brakes so i got the car on jacks and realized my calipers are locked up onto the rotors(both sides of my car i have drum in the rear) i tried bleeding my brakes (though i havent had any problems for the past 2 years with them) but no use. I tried the pumping of the brake pedalk but no use. I am out of ideas and use this car as a daily driver. Your help would be appreciated
Old Jul 27, 2004 | 04:23 PM
primer_crx's Avatar
Default Re: crx brake lockup problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (J-balint-k)
ya dude my friend had a similar problem. check the ebrake. it might be the springs to clamp the caliper.
Old Jul 27, 2004 | 04:25 PM
J-balint-k's Avatar
Default Re: crx brake lockup problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (primer_crx)
it is my front brakes not rear
Old Jul 27, 2004 | 08:20 PM
J-balint-k's Avatar
i could use some help......
Old Jul 27, 2004 | 08:25 PM
crexer's Avatar
hey man i had one of my rear disk calipers lock up last week and i just replaced the caliper; as for your case the front 2 are lock up? at the same time? Have you taken the calipers off the rotors and visually checked them? were your pads good? fluid check good? take them off and compress the pistons and try it again
Nicksteig
Mar 2, 2013 07:07 PM
95TEG
Jun 11, 2005 07:37 AM
kdogx
Oct 15, 2004 01:36 PM
SonicGSR
Mar 31, 2003 05:55 PM
