Crossmember radius bushing....replacement
Old Jul 27, 2004 | 02:06 PM
CRX T-Si's Avatar
Default Crossmember radius bushing....replacement
Does anyone know if there is some kind of metal bushing, metal washers that I can use to replace the bushing on the radius rods??
I have the energy suspension bushings already but I am trying to eliminate this nasty torque steer so I believe this is one of them.
Old Jul 27, 2004 | 02:29 PM
CRX T-Si's Avatar
Default Re: Crossmember radius bushing....replacement (CRX T-Si)
Damn no one knows??
I don't have cash to get the Z10 one, that is why I am looking for a cheaper alternative.
Old Jul 27, 2004 | 02:32 PM
Dyn0speed's Avatar
where can u get a complete set of bushings
Old Jul 27, 2004 | 02:35 PM
APEX CRX's Avatar
have you tried polyurethane ones? like from Prothane? does Energy have the radius rod bushing replacements? If so better look to an aftermarket x-member
Modified by APEX CRX at 3:49 PM 7/27/2004
Old Jul 27, 2004 | 02:43 PM
Dyn0speed's Avatar
Default Re: Crossmember radius bushing....replacement (APEX CRX)
do u guys have website
Old Jul 27, 2004 | 02:47 PM
Maddox's Avatar
you are better off get a aftermarket crossmember.
Old Jul 27, 2004 | 02:52 PM
Doodoo's Avatar
Default Re:
These are the only ones I have ever seen online. They are about mid-page.
http://www.opmautosports.com/p....html
But you are better off with an aftermarket member.
Old Jul 27, 2004 | 03:24 PM
CRX T-Si's Avatar
Default Re: Re: (Doodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doodoo &raquo;</TD></TR><TR><TD CLASS="quote">These are the only ones I have ever seen online. They are about mid-page.
But you are better off with an aftermarket member.</TD></TR></TABLE>
Damn your right, bushings for $126 for the stock X.
I am looking for cheaper alternative man.
Old Jul 27, 2004 | 07:13 PM
CWESTINAP1's Avatar
Default Re: Re: (CRX T-Si)
hey im having the same problem. i ordered the full race x member however it did not come w/ radius rod bushings. what should we do?
Old Jul 28, 2004 | 04:22 AM
CRX T-Si's Avatar
Default Re: Re: (CWESTINDC2)
PM'ed Ya
I would contact Full Race about the bushings, I don't see why they are not included if it uses bushings.
Anyways I am trying to avoid using rubber/urathane bushings and want something that is solid.
Old Jul 28, 2004 | 05:45 AM
Arvid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">PM'ed Ya
Anyways I am trying to avoid using rubber/urathane bushings and want something that is solid.</TD></TR></TABLE>
Progress makes spherical bearings for the radius arms instead of rubber/polyurethane. I can´t find any info on it on their website , but it was there before they redesigned it (though it was pretty well hidden at that time). They also make sphericalbearings for the control arms as well.
Here´s a link to an article with install pictures : http://www.hondatuningmagazine...ject/
Don JD
Sep 30, 2009 03:10 PM
sicegcivic
Mar 2, 2006 07:22 AM
99teggsr
Sep 11, 2005 11:11 PM
Toretto
Aug 15, 2004 05:23 PM
wuhungsixxx
Oct 5, 2001 11:03 AM
