usdm cams VS JDM ...quick question...
Old Jul 27, 2004 | 12:53 PM
TeamDOHCside's Avatar
Default usdm cams VS JDM ...quick question...
Hey guys im looking to buy some 00-01 USDM or CTR cams and i found a good deal on a few 99 JDM cams i was wondering if the profiles were the same as the 00-01 usdm cams or not, how do they stack up against the 98 spec usdm itr cams ect.
Thanks
Chase
Old Jul 27, 2004 | 12:57 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: usdm cams VS JDM ...quick question... (TeamDOHCside)
if i remember correctly ,00-01 ITR's have 1 degree more duration than the 98 specs. JDM- USDM ITR's are the same. CTR's are the only ones that are different with 2 more degree's of duration.
Old Jul 27, 2004 | 01:01 PM
Nvious R's Avatar
Manufacturer Intake Exaust
EF-1 m24 cams 12.1 mm, duration - 258 @1mm 12.1 mm, duration - 258 @1mm
Toda Spec A 11.6 mm, duration - 250 @ 1mm 11.2mm, duration - 240 @ 1mm
Toda Spec B 12 mm,duration - 255 @ 1mm 12 mm, duration - 245 @ 1mm
Toda Spec C 12.5 mm,duration - 255 @ 1mm 12.5 mm, duration - 255 @ 1mm
Jun Type 1 10.9 mm, duration - 265.3 @ 1mm 10.0 mm, duration - 268 @ 1mm
Jun Type 2 12.0 mm, duration - 266.6 @ 1mm 10.9 mm, duration - 265.3 @ 1mm
Jun Type 3 12.0 mm, duration - 265.3 @ 1mm 11.5 mm, duration - 265.3 @ 1mm
Spoon Sports 11.53 mm, duration - 256 @ 1mm 11.13 mm, duration - 245 @ 1mm
Skunk 2 stage1 11.58 mm, duration 252 @ 1mm 10.9 mm, duration 249 @ 1mm
Skunk2 stage 2 12.3 mm, duration 266 @ 1mm 11.8 mm, duration 262 @ 1mm
Skunk2 stage 3 12.8 mm, duration 273 @ 1mm 11.5 mm, duration 273 @ 1mm
Crower 63400 10.69 mm, duration - 244 @ 1mm 9.83 mm, duration - 231 @ 1mm
Crower 63401 11.38 mm, duration - 249 @ 1mm 10.54 mm, duration - 240 @ 1mm
Crower 63401T 11.81 mm, duration - 240 @ 1mm 11.30 mm, duration - 237 @ 1mm
Crower 63402 11.84 mm, duration - 258 @ 1mm 11.84 mm, duration - 251 @ 1mm
Crower 63402A 11.84 mm, duration - 246 @ 1mm 11.81 mm, duration - 239 @ 1mm
Crower 63403 12.04 mm, duration - 267 @ 1mm 11.84 mm, duration - 257 @ 1mm
ITR 00'-01' 11.5 mm, duration - 240 @ 1mm 10.5 mm, duration - 235 @ 1mm
CTR 00'-01' 11.5mm, duration - 243 @ 1mm 10.5 mm, duration - 235 @ 1mm
spoonfed95
Apr 3, 2003 10:48 AM
clemens
Sep 4, 2002 09:00 PM
mugenintegra16
Feb 24, 2002 12:10 PM
JinMTVT
Sep 12, 2001 09:50 PM
