What caused my motor to do this to my spark plug
Old Jul 27, 2004 | 11:01 AM
itralex's Avatar
Default What caused my motor to do this to my spark plug
I'm really really pissed after spending about 5 grand on rebuilding my head and tuning my new setup @ 2 local shops here in Vancouver, if i say the name, people will know what shop i'm talking about
now after we pulled the spark plug out, we put a new one in place of it, cranked it over several times and no contact, but we know for sure the intake valves are bent
this happened in a 7500 rpm second gear shift into 3rd then the motor just shut down and the noise sounded like it ran over a bunch of pebbles
here is my setup
B18C5 Motor 86000km
Vtec Chipped P06 ECU
Hondata S200
Toda Spec C cams
Rocket Motorsport Valvetrain
Rocket Motorsport high compression valves
Stock Cam gears with Toda timing belt
B&M FPR
B&M FP guage
RC 440 INjectors
and here is a picture of how the timing belt looked like....btw on 4000KM on this belt and the head
Old Jul 27, 2004 | 11:06 AM
jaydmcrx's Avatar
Default Re: What caused my motor to do this to my spark plug (HypeR1004)
Ummmmm something is seriously wrong to make your spark plug melt. And your timing belt looks horrible did you get it from autozone??? Stock cam gears with toda spec c's? And stock compression. How does the car run?
What didnt cause your spark plug to do that. Those cams have to be tuned. Atleast with a vafc wich wont even really help you. You will need a stand alone and some nice cam gears. Toda came gears are great. Start there, and get some compression for those damn things.
Old Jul 27, 2004 | 11:09 AM
itralex's Avatar
Default Re: What caused my motor to do this to my spark plug (jaydmcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">Ummmmm something is seriously wrong to make your spark plug melt. And your timing belt looks horrible did you get it from autozone??? Stock cam gears with toda spec c's? And stock compression. How does the car run?
What didnt cause your spark plug to do that.</TD></TR></TABLE>
The car is tuned on a Hondata Unit......this is not supposed to happen when tuned
and that belt ain't no el cheapo one, it's a Toda, Paid 250 CDN for it
car runs a bit better than stock and my CR is about 11.2
Old Jul 27, 2004 | 11:12 AM
jaydmcrx's Avatar
That doesnt look like a toda to me, and how did you tune properly without the use of cam gears.
Thats a toda timing belt. That doesnt look anything like yours unless its some kind that ive never seen before.
Old Jul 27, 2004 | 11:14 AM
itralex's Avatar
Default Re: (jaydmcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">That doesnt look like a toda to me, and how did you tune properly without the use of cam gears. And what stand alone are you using?</TD></TR></TABLE>
it's a Toda belt
Local shop here tuned it with a Hondata s200
it wasn't dyno tuned, it was street tuned to get the car running safely
Old Jul 27, 2004 | 11:15 AM
jaydmcrx's Avatar
Hmmm well that sucks man. I hope you figure this out, because when something like that happens, its not just a small problem.
Supernatural's Avatar
i highly suggest that you get the toda cam gears.....i know its sound stupid but you might rip the threads out of the cams.....you also my want to check if thats loose
Old Jul 27, 2004 | 11:17 AM
itralex's Avatar
Thats a toda timing belt. That doesnt look anything like yours unless its some kind that ive never seen before.</TD></TR></TABLE>
when i yanked the valve cover off, i was suprised to see no red on the belt
but i figured that it wore off on one of the pullies.
there is a slight hint of red left though
Old Jul 27, 2004 | 11:20 AM
jaydmcrx's Avatar
Default Re: (HypeR1004)
I think that shop is as shady as it gets. To get it running safely??? Look what happened. And it wouldnt just rub off. Not after 4k. no way
WAFFLES's Avatar
did you pull the head off?
itralex's Avatar
Default Re: What caused my motor to do this to my spark plug (SUPERNATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL &raquo;</TD></TR><TR><TD CLASS="quote">i highly suggest that you get the toda cam gears.....i know its sound stupid but you might rip the threads out of the cams.....you also my want to check if thats loose</TD></TR></TABLE>
yeah, looking to get them already......i have a set of St corsa's sitting here, i was planning to use them but decided not to anymore
the tension on the belt is pretty good, not loose
Old Jul 27, 2004 | 11:22 AM
itralex's Avatar
Default Re: (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">did you pull the head off?</TD></TR></TABLE>
not yet, haven't had time with work and suck, should be off by today
will post pics when it comes off
Old Jul 27, 2004 | 11:24 AM
itralex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">I think that shop is as shady as it gets. To get it running safely??? Look what happened. And it wouldnt just rub off. Not after 4k. no way</TD></TR></TABLE>
the head was built by a very very reputable shop here in van, even well known on HT
another shop tuned it.....btw, only hondata tuner here in vancouver
Old Jul 27, 2004 | 12:29 PM
PreStaged12s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HypeR1004 &raquo;</TD></TR><TR><TD CLASS="quote">
here is my setup
B18C5 Motor 86000km
Hondata S200
Toda Spec C cams
B&M FPR
B&M FP guage
RC 440 INjectors
Also part of your problem is TODA cams are SUPPOSED to be used with TODA valvetrain because of the design of the spring. I have a feeling what could have happened is a valve didnt close enough and there was piston to valve contact, the valve broke off inside the combustion chamber and smashed the spark plug, bet you if you pull your head off you will find the head of a valve and a big hole in the top of one of your pistons, that plug was not melted, it broke.
Old Jul 27, 2004 | 12:35 PM
94vtecmn's Avatar
Default Re: What caused my motor to do this to my spark plug (PreStaged12s)
Too hot of a plug may have contributed to the problem as well. Anytime you up the compression ratio, you need a cooler plug.
Old Jul 27, 2004 | 01:09 PM
10000rpm's Avatar
i think your timing not in the right place cus you bent your valves and your plugs hit the piston or it detonate bad that it melted the plugs i think its mechanical error cus your compression is low to have a piston to valve clearance...
Old Jul 27, 2004 | 01:37 PM
dirtyturtle's Avatar
Default Re: What caused my motor to do this to my spark plug (10000rpm)
what shop did it in van? i've herd a lot of horror stories about a lot of shops in van...
Old Jul 27, 2004 | 01:57 PM
G U E C O's Avatar
ouch
Old Jul 27, 2004 | 09:28 PM
itralex's Avatar
Default Re: (stock93cx)
Alright, after 3 hours, we pulled off the head and found a valve head embedded into the cylinder head
Result: hole in cylinder and metal shavings found in all cylinders oddley enough
well here are the pics
any input on how this happened?
Old Jul 27, 2004 | 09:42 PM
jaydmcrx's Avatar
Timing was way off. People who (tuned it) fucked it up bad. Could be a number of things. Call those ******** and tell them what happened. Did you do any of the assembly yourself??? If they did all of it then go back to them and make them pay for your repairs.
Old Jul 27, 2004 | 10:04 PM
untuned's Avatar
how were they tuning the car? by feel? or with a use of a wideband, what afr were you running?
Old Jul 27, 2004 | 10:36 PM
G U E C O's Avatar
was your timing ok?
Old Jul 27, 2004 | 10:45 PM
itralex's Avatar
Default Re: (untuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untuned &raquo;</TD></TR><TR><TD CLASS="quote">how were they tuning the car? by feel? or with a use of a wideband, what afr were you running?</TD></TR></TABLE>
Street tune with Wide band O2
I don't know the af i was running cause i don't have a guage
Old Jul 27, 2004 | 10:47 PM
itralex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx &raquo;</TD></TR><TR><TD CLASS="quote">was your timing ok?</TD></TR></TABLE>
the timing at the distrubutor was stock....the bolt was dead center
Old Jul 28, 2004 | 01:02 AM
Dammit_Dan_954's Avatar
Are u sure that is melted it looks beat up to me. Like a valve dropped or something. I feel your pain. Time to take off the head and take some more pics.
