Does my oil feed line look ok?
Old Jul 27, 2004 | 08:37 AM
.dave's Avatar
i HAS questions ?
Default Does my oil feed line look ok?
I've read several threads where people say going under the exhaust manifold is not a good idea, as the heat from the general area of the exhaust manifold and housing on the turbo can heat the oil up quite a bit. Does the oil feed on my turbo look like it will be ok, or should I go out the front by the compressor housing?
Old Jul 27, 2004 | 09:54 AM
m R g S r's Avatar
Default Re: Does my oil feed line look ok? (dave.g)
Personally, I think it looks alright, because it's not touching any of the extremely hot parts. I actually ran my feed line around the other side of the engine, and it was not near the turbine housing like yours is.
Old Jul 27, 2004 | 10:11 AM
-Trinitron-'s Avatar
Default Re: Does my oil feed line look ok? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Personally, I think it looks alright, because it's not touching any of the extremely hot parts. I actually ran my feed line around the other side of the engine, and it was not near the turbine housing like yours is.</TD></TR></TABLE>
Ditto...I think what some people do is they run the feed line between the runners of their manifolds...that would not be a good idea. You should be fine.
DeLucia
May 5, 2010 02:40 PM
CivicDude2k4
Sep 5, 2006 08:24 PM
AIRIC
May 22, 2006 04:54 PM
the.hamburglar
Aug 2, 2005 01:07 PM
GraphiteAccord
Jun 17, 2003 11:18 AM
