need help throwing codes 5, 6, 15, 16, 20
Old Jul 27, 2004 | 08:28 AM
cbrodac0424's Avatar
Default need help throwing codes 5, 6, 15, 16, 20
ok i posted in the tech forum but no one has responded so here it goes driving home yesterday and my car dies a mile from my house pushed it home and looked to see if i was throwing codes and i was 5, 6, 15, 16, 20 what are they and how do i fix it any help at all thanks i have the stock si (pm6) ecu and a dohc zc
Old Jul 27, 2004 | 08:36 AM
Default Re: need help throwing codes 5, 6, 15, 16, 20 (cbrodac0424)
bump need help asap
Old Jul 27, 2004 | 09:26 AM
5 map
6 coolant temp
15 ignition output signal
16 fuel injector
20 electric load
Old Jul 27, 2004 | 11:09 AM
crx_88_si's Avatar
WOW all those at once. I'd suggest looking for a loose ground connection! if you dont find any start diagnosis.
Old Jul 27, 2004 | 01:58 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
code 5
code 5 p2
code 6
code 6 p2
code 15
code 15 p2
code 16
code 16 p2
code 16 p3
code 16 p4
code 16 p5
code 20
code 20 p2
code 20 p3
Modified by fastcrxsi90 at 8:33 PM 7/27/2004
Old Jul 27, 2004 | 02:07 PM
4drEF's Avatar
Keyboard Humorist
Default Re: need help throwing codes 5, 6, 15, 16, 20 (fastcrxsi90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your distributor is bad and you either have things unplugged or bad sensors also...
How did you come to the conclusion that the distributor IS bad??
I can't see how you would get all those codes <U>at the same time </U> and it be a distributor.... and maybe some other things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">WOW all those at once. I'd suggest looking for a loose ground connection! if you dont find any start diagnosis.</TD></TR></TABLE>
That sounds more like it.
Or maybe a loose connector at the ECU or the firewall.
Old Jul 27, 2004 | 04:35 PM
Default Re: need help throwing codes 5, 6, 15, 16, 20 (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
I can't see how you would get all those codes <U>at the same time </U> and it be a distributor.... and maybe some other things.</TD></TR></TABLE>
i have no idea why i wrote that...i guess it was a long day at work.
Old Jul 27, 2004 | 05:56 PM
ok heres the deal i went to the local import shop (had my car towed by a integra lol) had the mechanic look at it and i have a short in my wireing somewhere under the dash invovles the ignition some how but now it works but i have to drive with all of the wires inbetween my legs so i dont bump the shorting wire thanks for all the advice i reset my ecu and i am throwing no codes i am not getting this
88crxdxfastwhip
Jul 12, 2005 05:56 PM
cbrodac0424
Jul 27, 2004 10:03 AM
