Need help
Old Jul 27, 2004 | 04:42 AM
aces1980's Avatar
Default Need help
I have a 91 si hatch with a d16y7. The problem that im having is finding a alternator belt that will work with this setup. I am using the alternator from my si cause i tried to use the one that came with the engine and the connector is different. Has anybody run into this problem? I have tried using the belt form a y7 engine and it breaks on me cause its to wide for the alternator pulley, i have also tried the original belt and that was too short. Please let me know what i can do to fix this. thanks in advance
Old Jul 28, 2004 | 04:30 AM
aces1980's Avatar
anyone?
Old Jul 28, 2004 | 05:00 AM
crx_88_si's Avatar
what belts have you tried?
Old Jul 28, 2004 | 10:37 AM
aces1980's Avatar
i have tried one for a a6 engine and one for the y7
Old Jul 28, 2004 | 10:39 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Need help (aces1980)
If all else fails, use the Y7 alternator and get the correct plug for it.
Old Jul 28, 2004 | 10:47 AM
aces1980's Avatar
i am actually tring that right now but the y7 connector only has 3 cables and my ef alternator connector has 4. does this matter? unless somebody messed with the wiring after all i did get it from the junk yard
end005
Jan 20, 2008 07:43 PM
tigueremalo
Jan 13, 2007 03:19 PM
StolenTeg
Aug 24, 2006 10:01 PM
Thundakat85
Mar 31, 2005 10:46 AM
