jdm d15b into an ef
So im lookin into buying an ef hatch and dropping in this jdm d15b.What is required for this motor to drop into an ef? since it is obd1.I also have a 93 si tranny and a p28.
JDM D15B ===> 88-91 Civic/CRX
basically the same as the D16Z6 swap into 88-91Civic/CRX
swap the Left Engine mount on the engine with the one from your stock engine,
Convert to OBD-1 and your set
a few wiring steps you can skip are:
rewiring the fuel injectors-Keep the OBD-0 injectors and resistor
If you find the JDM "P08 ECU they're dimepieces simply because
#1 the read the same singlwire 02 sensor as your 88-91 Civic/CRX that saves (3) extra wires the USDM P28 runs
#2 it doesn't look for VTEC pressure sensor another wiring step to skip
I know pictures are worth 1K words, but you can search and find more on this swap
it's pretty damn common
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRCCRX911 »</TD></TR><TR><TD CLASS="quote">I believe your 93 SI tranny is a Hydro Tranny,correct? If it is than you need to get a hasport hydro conversion. Or get a 91 Si tranny</TD></TR></TABLE>
^Not sure what this guy is talking about
Can't run a D series Hydro trans in a 88-91 Civic/CRX
NO the HASport offering will not help
Just source an Si trans
perfect match for the engine
LHC
Sep 22, 2003 05:21 AM
Veil_Side_
Nov 21, 2001 09:25 AM
