Gude Cams
Old Jul 26, 2004 | 10:49 PM
Slipknt777's Avatar
Default Gude Cams
What are your opinions on Gude cams. My 93 h22a came with them and i wanna know what you guys think....should i keep em or should i get some different ones. http://www.gude.com
Old Jul 26, 2004 | 10:57 PM
PrecisionH23a's Avatar
Default Re: Gude Cams (Slipknt777)
Gude sucks. Unfortunately I am still running gude cams on my set-up. They are turbo cams however.... for all I know they are probably stock cams that they never even worked on.
They have the absolute worst customer service in the whole import world. Go for some crowers, jun's, or skunk 2's.
Old Jul 26, 2004 | 11:01 PM
portenio78's Avatar
Default Re: Gude Cams (PrecisionH23a)
BRO....get those cams out of there. Way too many bad experiences myself with gude.
Old Jul 26, 2004 | 11:07 PM
Slipknt777's Avatar
how would i know which stage cams to get? im new to motor internals.
Also what is required to change cams?
Modified by Slipknt777 at 2:18 AM 7/27/2004
Old Jul 26, 2004 | 11:19 PM
Slipknt777's Avatar
well i just saw what it would cost to get new cams and i wont be able to afford them for a while. I got my stock cams still. should i put the stock ones back in or keep the gudes until i can afford some better ones?
Old Jul 26, 2004 | 11:20 PM
vuthe32's Avatar
i have a gude milled, port and polished cyclinder head.. works good.. no probs
Old Jul 26, 2004 | 11:37 PM
Sam1am26's Avatar
Default Re: Gude Cams (vuthe32)
My friend with an h22 got a complete gude head package with cams and all and it definitely wa not as advertised... I would recommend some crowers or some jun cams...
Old Jul 27, 2004 | 07:42 AM
98TypeSH's Avatar
Default Re: Gude Cams (Sam1am26)
Keep the stock cams in, sell the gudes if you find someone to buy them.
The difference in the "stage" of the cam, is how agressive the lift and duration is. As far as i know, Jun makes the most agressive cam unless you get a custom grind drag cam done or maybe crower 3 full drag cam. The crower 3 is horrible for street performance and they say race purposes only due to whacky idle. The Jun cam you can run without a problem, and not have idle jump. Skunk2 stage 2 are supposed to be pretty good, but ive always wanted jun so thats what i got. Shop around, dont buy something then regret it.
Modified by 98TypeSH at 10:12 AM 7/27/2004
Old Jul 27, 2004 | 11:07 AM
https://honda-tech.com/zerothread?id=939641
bigplansnocar
Sep 26, 2003 08:12 AM
