How do you run TCU Diagnostics?
Old Jul 26, 2004 | 07:14 PM
dailydriven91ex's Avatar
Default How do you run TCU Diagnostics?
Been searching this site and others like crazy for a write up, I know it is easy, however just don't know how to go about it on this car.
The green sport light is flashing and my car starts in a high gear(auto) unless I downshift to 2nd. It won't go into 1st or 3rd. I have found out it is from A failing TCU through search, however I can't figure out how to check the TCU. Thnx
Old Jul 26, 2004 | 09:02 PM
cmrvi1's Avatar
Default Re: How do you run TCU Diagnostics? (dailydriven91ex)
As many of you are aware, early 90's Accords regularly have transmission shifting problems (eg. S light flashing or on steady, D4 light flashing, trans takes off in 2nd gear). The most common cause of this is a burnt out TCM.
I have been rebuilding these computers for quite some time now and have some in stock ready for shipping, or I can rebuild yours.
For pricing, or more information, please email me at: cmrvi1@yahoo.com
Below is some info on how to check for codes, TCM location, and most IMPORTANTLY, how to check your TCM.
Behind the right hand corner of the dash on the passender's side (just below the glove compartment) you will find 2 connectors taped to the wire harness with blue tape ( unless someone previously removed the tape). One is a three wire connector (data link connector) the other is a two wire connector. By jumping the two wires on this connector, you check for engine and transmission codes.
With the ignition switch off, connect the two wires together. Have a pen and paper handy. Turn the ignition switch on. The S light (or D4 light if your car doesn't have the S light) should start to flash a code. Might be a combination of long and short flashes. A long flash stands for 10, and short flashes are 1. For example, if the light blinks: long-short-short-short, then that is a code 13. When you find out what code it is, post it and I can tell you what is going on. BTW, 90-93 Accords have a bad habit of burning out the trans computers. So sometimes you won't get a code. The light will just stay on steady when you jump the connector.
If the light doesn't blink when you jump the connector, then your TCM (transmission control module) might be bad.
To verify this, remove the TCM ( it's located under the rug on the passenger side bolted to the firewall. You will find two modules bolted to one bracket. The TCM is the smaller of the two, on the right.
To remove it, you'll need to remove the 4 bolts securing the bracket. Then, unplug both computer modules, and gently remove the bracket.
Next, unbolt the TCM from the bracket.
Remove the four screws that hold on the cover.
Look at the board carefully. If it is bad, you will find a burnt out resistor and a leaking capacitor. If this is the case, I can rebuild it for you.
Email at cmrvi1@yahoo.com and I'll give you more details.
This is the TCM
With the connector pointing down, the bad spot will be in the lower right corner
This is what the damaged part looks like up close
widewhite
Nov 20, 2014 03:49 PM
follie gatts
Feb 6, 2009 08:39 PM
figgs-ef
Oct 21, 2008 04:25 AM
doodooheadfart
Transmission & Drivetrain
Oct 8, 2008 12:01 PM
dc2long
Oct 21, 2006 04:46 PM
