weight of my 1989 crx hf kinda disappointed
Old Jul 26, 2004 | 06:20 PM
deftones0817's Avatar
Default weight of my 1989 crx hf kinda disappointed
Well I went to a local gravel place today and weighed my car. The guy said it was 2020 lbs with me in it and 4 gallons of gas. Here are specs
1989 crx hf (rear interior ripped out)
gsr flat five rims
stock rear drum brakes
1991 dx brakes up front
1988 si engine
ebay generic header
oem gsr intake tube with k&n filter
2 1/4 crushed bend pipe no cat no resonator
generic muffler
4 gallons of gas
i weight 135lbs
no ac all stuff in engine bay is ripped out also
That seems a little heavy to me. What do you guys think?
Josh
Old Jul 26, 2004 | 06:23 PM
TheAntiEndz0r's Avatar
Default Re: weight of my 1989 crx hf kinda disappointed (deftones0817)
the scale never lies
Old Jul 26, 2004 | 06:24 PM
sit220's Avatar
make sure how they weight ur car cause some of those places
they weigth the car by hundreds
im not sure
Old Jul 26, 2004 | 06:58 PM
91civicDXdude's Avatar
2020lbs aint bad including driver..how much do you weigh?
Old Jul 26, 2004 | 07:01 PM
Ivan's Avatar
senior gold member
sounds about right but remember those scales are made to measure alot more then 2k so its off. I would think its lower than that but not more then 100.
Old Jul 26, 2004 | 07:02 PM
Driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">Well I went to a local gravel place today and weighed my car. The guy said it was 2020 lbs with me in it and 4 gallons of gas.
Josh</TD></TR></TABLE>
it's about right. Ignore those guys who say they have 1800lb 2g CRXs... cause they are quoting numbers without driver and or engine
I've got a completely gutted '90 HF, b16a, at 2251lbs with me in it (170lbs)
Old Jul 26, 2004 | 07:05 PM
sit220's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">..how much do you weigh?</TD></TR></TABLE>
135lb
Old Jul 26, 2004 | 07:08 PM
crxtim's Avatar
Default Re: weight of my 1989 crx hf kinda disappointed (Driven)
it sounds about right. i had a 90 hf with 88 doors and other weight reduction. i weighed in at 2025 w/o driver 3/4 tank and full bottle of nitrous and this was at maple grove's scales.
Old Jul 26, 2004 | 07:43 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">2020lbs aint bad including driver..</TD></TR></TABLE>
That ain't bad. My 88 hatch weighs 2160 on its own.
2300 with me. I think it's heavy.
No weight reduction my ***** just getting fatter
B16
integra brakes all corners
and a 12" sub
Old Jul 27, 2004 | 09:49 AM
Mind too slow's Avatar
that sounds about right considering a 95 240sx weighs around 2800-2920lbs almost 1000lbs more
Old Jul 27, 2004 | 10:15 AM
crx_88_si's Avatar
Default Re: weight of my 1989 crx hf kinda disappointed (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">sounds about right but remember those scales are made to measure alot more then 2k so its off. I would think its lower than that but not more then 100.</TD></TR></TABLE>
No that's not the case. they are very accurate. they dont measure by pressure, but by stress on torsional beams.
Our scale at work is accurate from a person or a bunch of water on the scale to a 60,000kg tractor trailer.
they usually weigh in 10lbs or kg increments though.
Old Jul 27, 2004 | 10:27 AM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">
I've got a completely gutted '90 HF, b16a, at 2251lbs with me in it (170lbs)</TD></TR></TABLE>
I have a CRX that weighs less than 1800lbs with driver and engine... and I have the corner weight scales to prove it. It is possible, there is a lot of weight to remove off of these cars. Keep in mind that I'm starting with an 88 HF.
Old Jul 27, 2004 | 11:32 AM
ServiceAdvisor's Avatar
Wow, you guys make me feel fat. "135lbs" "140lbs" I suppose your all 5'9? lol, I'm 6'1, 175lbs and I thought I was skinny. - Darrell
Old Jul 27, 2004 | 11:35 AM
Fred.Rodgers's Avatar
Default Re: (OldSiHatch)
****, 6'2" ~215.
2g crx stock interior ~2480 with full tank
i need to go on a diet
Old Jul 27, 2004 | 11:37 AM
JOEY F.'s Avatar
yah that weight sounds right. I have a gutted 1991 DX hatch and mine weighed 2000 flat without me in it. Thats it ...2 seats, no AC, No carpet, no rear seats or rear plastics. So youre doing a-ok. SOHC by the way.
Old Jul 27, 2004 | 11:40 AM
bossman032's Avatar
Default Re: (JOEY F.)
IC
I thought the crx hf weight was around 1800 guess not
interesting
Old Jul 27, 2004 | 01:09 PM
Smokinsax's Avatar
The Boot
had my car weighed at Firebird International Raceway in Phoenix, AZ
87 Si hatch
half gutted
B20BVTEC
2010 lbs w/o driver
I was way dissapointed. Everyone was like it's gunna weigh like 1800lbs?!?!?! Well guess again.
Old Jul 27, 2004 | 02:41 PM
Default Re: (Smokinsax)
well i just want to get it 2 19xx lbs. I always remove one seat and my 10lb battery died so i had to replace with a stock weight battery. So I guess when im at drag strip i should be a little lighter. Either way im not really upset. And a 1989 crx hf should weight close to 1840 1860 with no driver and i think no gas and stock engine. I belive si engine weights more and dx hubs are heavier than hf front brakes. But it should be good.
DEF
Old Jul 27, 2004 | 05:55 PM
Ivan's Avatar
senior gold member
Default Re: (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">IC
interesting </TD></TR></TABLE>
for the 88. his is an 89. 89 hf is around 1900. I wonder if his had ac or not. I know he says it doesn't have it but I wonder if it had it before.
Old Jul 27, 2004 | 07:08 PM
AngelR's Avatar
Default Re: (Ivan)
My 91 crx si weighed in at 2300 with me in it (140ish) full int, ac, b16 etc.
Old Jul 27, 2004 | 07:52 PM
90crxsib16's Avatar
Default Re: (AngelR)
Not trying to steal your topic, but where can the average person get their car weighed(sp?)?
Old Jul 27, 2004 | 07:58 PM
AngelR's Avatar
Default Re: (90crxsib16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxsib16 &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to steal your topic, but where can the average person get their car weighed(sp?)?</TD></TR></TABLE>
Dumps, truck stops (some), freight handlers, and your local track.
Old Jul 27, 2004 | 08:16 PM
Gant's Avatar
Default Re: (eda6 hb)
how much does it cost r they really allowed to wiegh cars or it just depends on where u go?
Old Jul 27, 2004 | 08:18 PM
hondaguyef's Avatar
Default Re: (Ivan)
for the 88. his is an 89. 89 hf is around 1900. I wonder if his had ac or not. I know he says it doesn't have it but I wonder if it had it before. </TD></TR></TABLE>
He had AC before. We took it out though.
Old Aug 13, 2004 | 10:38 PM
90crxsib16's Avatar
Default Re: (hondaguyef)
Went to the track tonight. Very disappointed. CRX Si/B16 weighed 2450 with me in it. This is with the Wings West RS kit, sub, camcorder, spare tire, 1/2 tank of gas, etc...no weight reduction at all, YET. Ended up with a 15.6 as my best 1/4 ET.
