FS: JDM B20b / OBD1 / GSR Tranny / NJ
Old Jul 26, 2004 | 05:52 PM
jaysonx's Avatar
Default FS: JDM B20 Swap / OBD1 / GSR Tranny / NJ
Quick Facts:
JDM B20B
#5218106
OBD1
GSR Tranny
Rare P8R head
LS Intake / Throttle Body / Alternator / Sensors / ETC
JDM ITR 4-1 Header / Fidanza Flywheel / Exedy Racing Clutch / Axles / Starter / All With Less Than 12,000 Miles!
DelSol VTEC Linkages / Front Tranny Mount
Estimated Block Mileage is around 60k
Perfect for swapping into an EG chassis! Lay waste to B16a Hondas while running regular grade!
This is a nice clean swap located in Southern NJ. Engine is a JDM B20b. I have owned this swap for approx 2 years, before which it was owned by the user chidoks on this forum. The block was installed in my 1993 delSol, which had an unfortunate run in with a concrete barrier while traveling at approx 30-35mph. The front frame of the car was bent in, totaling it. Fortunately the engine was unharmed in this incident. (Crash Photos Here)
The motor ran great afterwards, and I actually drove it around the junkyard where the car was stored for a little bit just to make sure. It also drove right onto the car carrier that I rented to haul away the wreck with no trouble whatsoever.
This Swap is a stock JDM B20b with LS intake manifold / throttle body / distributor / alternator and sensors. It is an OBD1 Swap. The block is mated to a GSR transmission that has no grinds, but can sporadically be stubborn shifting into 4th gear and reverse. However, this is the exception and not the rule. I never considered it problematic enough to drop the tranny and crack it open to have a look.
There is also a Fidanza flywheel and Exedy Racing clutch installed, both with less than 12,000 miles on them. The axles were also replaced within the past year, and have less than 12,000 miles on them as well. The wiring harness that is included is a 1993 Civic DX harness with an extended wire for the O2 sensor (red in photo).
This also comes with both delSol VTEC shift linkages, front tranny mount and JDM ITR 4-1 header (less than 12,000 miles as well).
The Driver Side AC mount is the standard B20 mount, which will fit fine unless you are mounting on a civic and want to keep your AC. In this case you will need to find a delSol VTEC AC mount.
Compression was checked within the past 10 months, and all of the cylinders came up right around 190 except cylinder 1, which read 178. My mechanic told me to monitor it, but not to worry too much as it was still within spec. I have had no oil consumption with this motor.
The only thing that you will be missing for this swap is the upper tranny mount, which was damaged in the accident. (When the sub frame bent, it ripped the bushing). That aside, everything needed to swap into a EG chassis is included with this swap.
Absolutely will not ship. Must be picked up at its present location, which is in a storage unit in Mays Landing, NJ. I have a hydraulic lift present, which can assist in picking up the swap.
Asking: $2300 for the entire package - Will Not Part Out /// SOLD
Also comes with an extra driver side axle / intermediate shaft and alternator if desired.
More Pics Can Be Found Here
Please PM or reply if interested.
Modified by jaysonx at 8:57 PM 9/14/2004
Old Jul 26, 2004 | 07:27 PM
jaysonx's Avatar
bump
Old Jul 26, 2004 | 08:45 PM
navin's Avatar
Default Re: (jaysonx)
will you sell the longblock?
Old Jul 27, 2004 | 05:33 AM
jaysonx's Avatar
Default Re: (navin)
Don't want to part out, sorry.
Old Jul 27, 2004 | 07:15 AM
hondatwincam's Avatar
Default Re: FS: JDM B20b / OBD1 / GSR Tranny / NJ (jaysonx)
Will you sell me just the sensors and connecting rods?
Bwhahahahaha!
Old Jul 27, 2004 | 08:47 AM
Can you sell me just the dipstick and the sparkplugs?
Old Jul 27, 2004 | 12:41 PM
jaysonx's Avatar
haha very funny!
Old Jul 27, 2004 | 12:56 PM
brent_G's Avatar
does this block have a knock sensor? which b20 is it? high compression or the low compression one?
what year is it?
Old Jul 27, 2004 | 01:10 PM
jaysonx's Avatar
no knock sensor, it's a JDM B20b, but it is running the USDM B20z 2 layer headgasket and was rebuilt on the bottom end with B20z pistons / rings by the previous owner. contact chidoks concerning that if you have any questions, as he did the work.
I believe it is a 97 or 98
Old Jul 27, 2004 | 06:14 PM
jaysonx's Avatar
Old Jul 28, 2004 | 06:07 AM
jaysonx's Avatar
Old Jul 28, 2004 | 07:15 AM
chidoks's Avatar
The engine was originally a jdm b20b with the 8.8:1 CR pistons... I ordered the 9.6:1CR B20Z pistons brand new from honda... The motor was rebuilt with the b20z pistons and brand new gaskets, bearings and belts... The valves were also replaced at that point because of minor valve tap.. The entire motor was hot-tanked during the rebuild... If i had the money, I'd buy the swap back from Jason
Old Jul 28, 2004 | 05:14 PM
jaysonx's Avatar
PM Bump
Old Jul 29, 2004 | 11:28 AM
jaysonx's Avatar
bump bump
Old Jul 29, 2004 | 11:57 AM
Sliced Beard's Avatar
what is the head casting number?
p75, p8r, etc.........
Old Jul 29, 2004 | 02:56 PM
jaysonx's Avatar
Default Re: (dirtyd463)
This block has the Rare P8R head.
The year cause PPL asked.
Modified by jaysonx at 7:21 PM 7/29/2004
Old Jul 29, 2004 | 03:12 PM
it is not ultra rare....just not terribly common
Old Jul 30, 2004 | 05:24 AM
jaysonx's Avatar
Default Re: FS: JDM B20 Swap / OBD1 / GSR Tranny / NJ (jaysonx)
Old Jul 31, 2004 | 09:20 AM
jaysonx's Avatar
bumped
Old Jul 31, 2004 | 09:46 AM
chidoks's Avatar
bump for jasons swap...
Old Jul 31, 2004 | 12:19 PM
nevamind's Avatar
will you sell the shiftlinkage?
Old Jul 31, 2004 | 12:54 PM
jaysonx's Avatar
Default Re: (HIStateEG6)
Nah don't want to sell the linkages. The main linkage is still attached with the bitchpin.
Get your linkage here
Thats where I got mine from.
Old Aug 2, 2004 | 06:16 AM
jaysonx's Avatar
Bump - New Low Price!
Old Aug 2, 2004 | 03:03 PM
jaysonx's Avatar
Old Aug 4, 2004 | 10:15 AM
jaysonx's Avatar
Bump - Swap Still Available
