Help! Installing 2nd Gen 'Teg Seats In 89 DX Hatch!!!!
Can anyone find an old thread or perhaps some good detailed instructions on how to get them to fit in my hatch!!!????? Please!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.4thgenerationcivic.com »</TD></TR><TR><TD CLASS="quote">
The Integra seats do fit in the 88-91 Civic with modification. I used 90 Integra seats, 94+ Integra seats might be easier to install. This mod was not easy. From the Integra you will need all parts/railing that come with the seats. You need to remove one side of the railings from the Integra seat and swap the original Civic railing to it. After you do this you must drill new holes to mount the railings. Makesure you remove the seat belt holder from the Integra seat also or the seatswill not fit in your car. To make the seat look a little nicer you can add youoriginal Civic plastic covers on the side "you will need to drill andcut". Once the seats are together you will need to put them in your car. The first thing you will notice is that you will have a 2+ inch gap in the rear of the seats. To correct this you must get some spacers "hardware stores sell them" I used 2 of them. Once the seat is seated correctly you will have to enlarge the original holes on the mounting brackets. I do not recommended redrilling your floor board since this will not be as strong as your factory. </TD></TR></TABLE>
swap the seat pans and sit stunna style...its the safest way, but then if u dont know how to cut and weld the recliner bracket so itll position itself up all the way then u have to have it all reclined back a little bit. BUT ur bolts for the floor will line up all correct.
safest way to do it in my opinion
tlkolrod
Apr 23, 2007 02:06 AM
D15Bbigred
Mar 12, 2006 10:11 AM
b18 pwr
Feb 19, 2004 08:59 AM
Hondasaurs
Jan 31, 2003 08:05 AM
