starter kill .....which wire is the cranking wire?
Puttin in the alarm and starter kill and I'm not positive on which wire I should tap into for the starter kill. It says to tap into the cranking wire.
I don't know where exactly it is located on the ignition side of things, but I do know it is the little spade connecter that connects to the starter. Even though that is kind of a Duh! statement mine broke off the other day so it was rolling starts for me
but ultimate security until I patched it up
yeh the black wire w/the white stripe looks to go to the starter itself, and the white wire w/black stripe goes to the main fuse box under the hood...gotta love .pdf manuals, i just didn't wanna hack up my brand new ign. switch wiring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman »</TD></TR><TR><TD CLASS="quote">still workin on the install. I think i've got about 5 or 6 hrs tied up in this so far, but patience and time make a clean invisible install</TD></TR></TABLE>
nice umm what alarm did u use..?
DEI??
DEI??
no, crimestopper....cheap and works...(hopefully)
One more ? When wiring up the door trigger wires you need to either run a positive door trigger wire or negative door trigger wire. I traced the wire for the door trigger in the drivers door wiring trough, but set it up as the negative door trigger, b/c it said that's what most cars use.
Although in my manual, well i'll show ya what it says.
btw that's a green wire w/red stripe that i spliced into
for most cars u use negative
u can make many trigger as u want a
it got to show negative whwn open
the wire that shows negatyve when all doors are open goes to the green wire in the alarm
i gots it done, can't tell that a thing is under there, i think i'td of been quicker to just remove the dash, but i laid on my back contorted and twisted wishing i had midget arms up in there
http://cgi.ebay.com/ws/eBayISA...%3AIT
that's it righ tthere.....great fast shippin and it's got a good range on the remote also
