Apex VAFC
I'm looking for some info. I'm researching the Apex VAFC (old and new).
First, I wanted to make sure that this will work on my car.
1990 Civc
B16
Pr3
Second, How easy is it to hook up?
Third, What do you guys think of the 2 products? I have not bought one yet so please be honest.
Thanks,
Rob
1990 Civc
B16
Pr3
Thanks,
Rob
both will work on your car.
they both are pretty easy to install. i suggest soldering it in.
they are great products, but kinda too flashy . thieves love this stuff and not too mention cops.
so hide that thing
so hide that thing
Jurassic Four May I ask what is your question???
The motor swap or the AFC
I have the B16a in my CRX, Check my homepage.
Don't have updated pics but you can use as ref.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four »</TD></TR><TR><TD CLASS="quote">Stealing thread... do they come with a kit or at least directions to put it on? Anyone installed on B16 swapped obd0? Any tricks?</TD></TR></TABLE>
i installed mine on a PW0 ecu wiring harness...if it comes with instructions and a wiring diagram (like mine did) you should have no problems. It took me 2 hours with a dinner break lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cykociv »</TD></TR><TR><TD CLASS="quote">It comes (new) with everything you need.
I'm putting mine where the climent controls use to be.
thats where mine is
(pic before any stereo)
simple to install if you have ANY experience with wiring AT ALL... they give you diagrams just make sure your using the right one
and a second grader could do it.
Modified by 4inspeed at 10:31 PM 7/27/2004
Modified by 4inspeed at 10:32 PM 7/27/2004
</TD></TR></TABLE>thats where mine is
(pic before any stereo)simple to install if you have ANY experience with wiring AT ALL... they give you diagrams just make sure your using the right one
and a second grader could do it.Modified by 4inspeed at 10:31 PM 7/27/2004
Mine is not daily driven.......
You can hook the fan up to a switch and it works just the same. That is what I have done..........well 2 switches.......one for the fan and the other for the heating element. Works great for what I use it for.
i have a b20 block with gsr head and gsr lsd tranny
when i race i always shift on every gear when i get to 8000 rpm
sometime 8300 cince i sold my tachometer lol
my vtec kicks in at 5000 rpm
when racing from stop i rev my engine to 2500 rpm so i won't spin to much
here is the question : where should i set my vafc vtec to kick in?
3000?, 3500?, 4000?,4500?
i am trying to leave bihind the b18c1 on a 1995 eg lol
he keeps up with me but i am wonder how i will do after the vafc have been set
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20VTEC(V8KILLER) »</TD></TR><TR><TD CLASS="quote">i have a b20 block with gsr head and gsr lsd tranny
he keeps up with me but i am wonder how i will do after the vafc have been set</TD></TR></TABLE>
well unless your getting it tuned while changing the vtec crosover point, there is no point in changing it.... it will most likely bog down or loose power without being tuned. mine is still at the stock crossover of 4800 i used it for a a/f tuner not to change the engagement of vtec.
i do sugest that anyone who gets this doesnt have a stock motor, it wont do much for you if you do. i have a semi built head and i wanted a little extra tunability without going engine management.
and to answer the ? about the ac controlls. i ripped it out. along with every other peice of my ac/heat system. not a big deal to me. dont drive the car all the time. just a have fun car.
Ok cool, Im putting one in my 90 Si HB so which diagram should I use, they only have it for 92-up Is the 90 ecu wiring harness the same just minus the vtec and vtm???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four »</TD></TR><TR><TD CLASS="quote">How does it measure air fuel??? I have my 02 sensors unplugged. Will that affect how the Vafc works?</TD></TR></TABLE>
It doesn't measure Air/Fuel, nor does it require o2 sensors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si »</TD></TR><TR><TD CLASS="quote">
I'm all about that mount, but put into the center of the bottom recessed into the plastic hood a lil bit.
</TD></TR></TABLE>I'm all about that mount, but put into the center of the bottom recessed into the plastic hood a lil bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
It doesn't measure Air/Fuel, nor does it require o2 sensors.</TD></TR></TABLE>
Oh, so it doesnt measure it... it just changes it?? Thats cool.
