need help with wiring b18c1... pics included
i need plugs for these 2 sensors. not sure what the yellow one is but i know the green is the vtec selonoid.
I Also need a plug for this sensor. What is this one called.(the white one)
also on the bottom of the block by the oil pan this was busted. pay no attention to the green wires or the weird blue wire connector. My questions is can I use the one from my d series motor in the following picture? the dseries one has 3 wires as you can see (blue, white, black). and the busted one only has 2 wires (blue and white). I'm assuming blacks the ground so could i use this?
In the first pic, the yellow is the Vtec solinoid plug, the green one is the Vtec oil pressure sensor/switch.
The second pic is you IAT (intake air Temp) sensor
The third pic is your Crank TDC sensor
PrestonCRX
Apr 7, 2006 06:30 PM
donkiman
Jul 26, 2004 02:26 PM
