Oil in Sparkplugs
Old Jul 26, 2004 | 11:22 AM
ZexyAccord's Avatar
Default Oil in Sparkplugs
Hey guys I found some oil in my 3rd spark plug today. What can be causing it. How do i fix it? Is it something i can do at a parking lot. If Not, how much will the average shop charge for somehting like this?
Any input would be appreciated!
Old Jul 26, 2004 | 11:31 AM
sietekk's Avatar
Default Re: Oil in Sparkplugs (ZexyAccord)
i'm not an expert, but i've heard several engine guys i know talk about blown piston rings. that involves ripping the entire engine down and installing new rings around the pistons to create proper sealage. otherwise oil leaks up and into the cylinder. i don't know, but could be a headgasket too. either case, you are gonna shell out moola for this. hope its not these two!
Old Jul 26, 2004 | 11:46 AM
JimBlake's Avatar
Where exactly is the oil? Oil above the threads of the spark plugs comes from the spark plug tube seals. Kinda like part of the valve cover gasket, but sometimes sold separately.
Oil on the firing tip is more serious. But that can simply drip there while you're taking the plug out.
Old Jul 26, 2004 | 05:24 PM
pyrojeff's Avatar
If you pull the boot of the spark plug wire out and see oil on there, its probably just bad spark plug tube seals. They cost like $1.50 each, but most dealerships will only sell them in sets of 4. As far as install, its extremely easy, dont spend $100 for a shop to install it.
Just remove all of the bolts to the valve cover and remove all of the spark plug wires. Once the valve cover is off, turn it over and around the spark plug holes you'll see where the tube seals go. Replace them and you're set.
You might also want to replace the valve cover gasket, as it really isn't that great of an idea to reuse that gasket. That usually costs around 10 bucks.
Old Jul 26, 2004 | 06:14 PM
madd's Avatar
Default Re: Oil in Sparkplugs (pyrojeff)
dont forget about the lower spark plug tube seals...take the rocker arm assembly off and look underneath it...
cjwang2
Sep 30, 2015 10:17 AM
superslow-oto
Jul 7, 2008 06:52 PM
aWeimaraner
Jan 25, 2008 10:52 AM
hondaracing1on12004
Dec 13, 2004 02:05 PM
Mr. Softee
Nov 16, 2001 05:25 PM
