94-97 fenders the same as 98+?
In order to replace the fenders, you'll have to remove the bumper. The bumper has a bracket connected to the fender, along with plastic plugs. Another bracket is connected from the outer firewall to the inner fender. I bent the one that was in the inner fender....made it hard to match up fenders.
fender installs are KIND OF a bitch....you've gotta get under your sideskirts/etc....
and be real careful when you first open your door after you've got the piece on... if it don't fit perfectly, you'll have contact btween the fender and door as you open it..... you can **** your **** up that way... i did
