FS: H23 MOTOR WITH TRANSMISSION AND ECU IN WASHINGTON
Motor has about 150,000 miles on it. It came out of my '92 SI in december and has been sitting in my garage since. Everything ran fine when i took it out except it was putting out a nice, healthy puff of smoke when started and under accelleration. Has all plugs and sensors except Throttle Position Sensor, and knock sensor, which both broke off while being pulled out of the car. I took the distributor and fuel rail off it to put on my H22 and put the JDM fuel rail and distributor in their place.
The tranny comes with the motor and is all fine except third gear grinds some when putting it into gear. I do not have the wiring harness because I is still in my car on the H22.
Engine, Tranny and ECU all come together but might be willing to part out if it seems as if it would be worth it. If i part out the tranny and/or the ECU, i would be willing to sell just the H23 block itself.
I will try to get pics put up over the weekend, but this is all i have for now:
I have disclosed everything wrong with these items that I know of, if I happen to think of anything else i will be sure to let you know. The last thing i would want to do is improperly advertise this motor.
Make offer
Make offer
