Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Finally my car will be Koni Improved
Old Jul 26, 2004 | 08:53 AM
Solracer's Avatar
Default Finally my car will be Koni Improved
I got a great deal on a set of yellows (275 shippped used for 10,000 miles) and was wondeing since I use threaded sleeves do you even need the bottom pearch, or is that where the sleeve rests?
Thanks!
Old Jul 26, 2004 | 08:54 AM
TeamSlowdotOrg's Avatar
Default Re: Finally my car will be Koni Improved (Solracer)
If you have Koni-specific sleeves (I assume not because you've been using them before the konis) then you just use the circlip. If you don't, I think you have to use the perch.
Old Jul 26, 2004 | 08:59 AM
Solracer's Avatar
Default Re: Finally my car will be Koni Improved (TeamSlowdotOrg)
Yeah the not the koni sleeves, so I sue the perch no biggie.. I am excited to finally get some real shocks... anyone want set of AGX's with about 50,000 miles of autocrossing and track events on them? hehe
Old Jul 26, 2004 | 01:17 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the not the koni sleeves, so I sue the perch no biggie.. I am excited to finally get some real shocks... anyone want set of AGX's with about 50,000 miles of autocrossing and track events on them? hehe</TD></TR></TABLE>
PM CRX Lee, they (Koni) have some special purches that go on top of the circlip for using C/O's. If you just put the C/O sleeve on top of the circlip it can snap off and you'd be hating life.
Old Jul 26, 2004 | 03:21 PM
D21X's Avatar
Default Re: Finally my car will be Koni Improved (nonsense)
With my Skunk2 Coilovers, i had to buy washer type things to put over the circlips so my sleeve would be held on the shock. Costed me ~$40 through Koni.
Old Jul 26, 2004 | 06:19 PM
sinister6's Avatar
to me AGX is better then the konis..
Old Jul 26, 2004 | 06:21 PM
CRX Lee's Avatar
Default Re: (sinister6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">to me AGX is better then the konis..</TD></TR></TABLE>
To each his own. We'll wave as we go bye.
Old Jul 26, 2004 | 06:29 PM
sinister6's Avatar
Well, i have used both.. Both are in the same league IMHO.. the AGXs corners are slightly better but the Koni seems have better shock absorbing.. just my personal point of view tho.
one worst thing is i think Konis built quality is not as good as anyone thinks. mine are sort of bent after a hard drop into a porthole..which i never think that little force can be that "hard" to twist the shock
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the not the koni sleeves, so I sue the perch no biggie.</TD></TR></TABLE>
You have IM. Don't use just any sleeve on the Koni without mounting it properly or you will likely have trouble. Take a little extra time and do it right for teh long run.
Old Jul 26, 2004 | 06:34 PM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">Both are in the same league IMHO..
If you would like to see some real dyno data comparing several brands, check out: http://www.koni-na.com/presentations/civic/
There are a number of issues but this info shows actually what forces the shocks generate, what the adjustments really do, etc.
Old Jul 26, 2004 | 06:40 PM
ryan12321's Avatar
Default Re: (CRX Lee)
AGX is a good shock, but doesn't compare to a koni. I am using the AGX's on my car and am happy with their performance but I will be changing shocks soon, most likely to konis.
Old Jul 26, 2004 | 06:48 PM
MaddMatt's Avatar
Default Re: (ryan12321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Well, i have used both..</TD></TR></TABLE>
Me too.
Matt&lt;---pissed I didn't install Konis a long time ago...
Old Jul 26, 2004 | 07:16 PM
sinister6's Avatar
now that i have changed to Buddy Club RSDamper. Its like from Hell to Heaven..
but yea , honestly Konis are pretty good..
Old Jul 26, 2004 | 07:18 PM
Old Jul 26, 2004 | 08:09 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">now that i have changed to Buddy Club RSDamper. Its like from Hell to Heaven..
but yea , honestly Konis are pretty good..</TD></TR></TABLE>
Are the Buddy Club's rebuildable (in the US)? I know that some TEIN's are and some aren't.
Old Jul 28, 2004 | 05:39 AM
Solracer's Avatar
Default Re: (nonsense)
Well I have the shokcs in my hand, and to my suprise the have 5 adjustments for the perch height? I guess there nuespeed koni's then, is there any way else to tell if they are the nuespeed koni's?
Old Jul 28, 2004 | 06:10 AM
Solracer's Avatar
Default Re: (Solracer)
Looks like I answered my own questions, there is an SP3 after the part number in the shock. So I know one difference is the 5 adjustable slots on teh shock, btu is there any differnce in the valving than ots koni?
Old Jul 28, 2004 | 06:21 AM
Solracer's Avatar
I found this on the Neuspeed web site " 20mm shorter droop length for use with lowering springs." What does that mean...? I have an Idea, but I would like to here anyone else's thoughts.
Old Jul 28, 2004 | 12:00 PM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">I found this on the Neuspeed web site " 20mm shorter droop length for use with lowering springs." What does that mean...? I have an Idea, but I would like to here anyone else's thoughts.</TD></TR></TABLE>
When you jack the car up and pull the wheels off the ground, the car has less wheel droop and your springs are more likely to hold in position with preload if you hav short free length aftermarket springs. When teh car is on the ground and fucntioning as normal, there is no difference. The valving is exactly the same with Sport. Check to make sure you got all the hardware including the 12mmID top mount sleeves.
Old Jul 28, 2004 | 12:28 PM
Solracer's Avatar
I tired calling you and it said you were out of the office! I think I have all the hard ware but I am not sure what you mean by the top sleeves. I left my Cell on your voice mail at work so you can call me, I have the shocks sitting right next me.
Old Jul 28, 2004 | 03:10 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">I tired calling you and it said you were out of the office! I think I have all the hard ware but I am not sure what you mean by the top sleeves. I left my Cell on your voice mail at work so you can call me, I have the shocks sitting right next me.</TD></TR></TABLE>
The top sleeves are #12 in this pic. You need the Koni ones because your stock ones have too small of an ID to fit the fatter Koni shafts. You should have 4. Push the stock ones out of the bushings (#6), and push these in. I think you also need another #5 washer too.
Old Jul 28, 2004 | 03:12 PM
.RJ's Avatar
.RJ
Koni shock install write up here: https://honda-tech.com/zerothread?id=891136
Old Jul 28, 2004 | 07:05 PM
Solracer's Avatar
Default Re: (.RJ)
Thanks Guys I think I have the parts.... and I can't wait to get them install unfrotunatly I will not not have them on by VIR. However I am going to take this change to swicht my coil overs springs and finally put the stiffer ones out back .
Old Jul 29, 2004 | 05:44 AM
sinister6's Avatar
whats that no.7?? upper mount? anyone can inspire me? im still confusing about the upper mount thing after all these years.. grr
Old Jul 30, 2004 | 06:48 AM
sinister6's Avatar
also yes the buddyclubs are rebuildable..
