z6 swap problems, general info please help.
Old Jul 26, 2004 | 07:59 AM
RicedREX's Avatar
Default z6 swap problems, general info please help.
im swapping in a z6 in my crx and ive ran into a couple problems...first the fuel pump wont kick on when I start the car, the fuel pump is fine becasue I ran it with a battery and it worked fine. Second I cant get my tachometer to work...if anyone could point me in the direction the wires go from the cluster that would be appreciated...third, im guessing around 4-5k rpm the motor starts skipping sorda, it runs fine until then...its like, duuuuuuuuuuuuuuuududududududud, if that helps, vtec is not hooked up but when we did it still did it, it has a big cam btw, any help is appreciated thanx.
Old Jul 26, 2004 | 06:42 PM
RicedREX's Avatar
c'mon
Old Jul 27, 2004 | 12:43 PM
RicedREX's Avatar
hmm
Old Jul 28, 2004 | 01:52 PM
RicedREX's Avatar
cars still in the garage.
Old Jul 28, 2004 | 02:00 PM
Si_Racer13's Avatar
Default Re: (RicedREX)
more info would help.
what ECU? what trim crx?
Old Jul 28, 2004 | 02:51 PM
ComputerJLT's Avatar
Default Re: (Si_Racer13)
checked your main realay?
have a CEL? obd0/obd1?
Old Jul 28, 2004 | 02:53 PM
Creepshow S60's Avatar
Default Re: (ComputerJLT)
well if for sure the fuel pump works, only one thing to check...wiring. oh and of course there's the main relay problem some have (myself included).
Old Jul 29, 2004 | 09:06 AM
RicedREX's Avatar
p28 in a 90 dx, ok the fuel pump we wired up and its fine now and the engine is running smooth...now I just hope vtec works...and btw can anyone tell me what/where the tach runs off of?
Old Jul 29, 2004 | 09:10 AM
Bserieskllr's Avatar
tach runs of blue wire off dist. but you say your using a zex stage 3 cam havent seen it yet??? you sure its not the stage 2? i got a satge 2 and it 260 vtec int./268 exhaust.
Old Jul 29, 2004 | 10:46 AM
RicedREX's Avatar
yea its stage 2...sorry for my ignorance but what do those 260/268 #'s mean?
fin781
Apr 8, 2011 10:33 AM
civic2liters
Jun 1, 2008 08:11 PM
FrOsTwHiTeDC4
Jul 7, 2007 06:28 PM
sohczchf
May 19, 2005 11:14 PM
