When is a MSD type ignition necessary?
Old Nov 26, 2001 | 05:53 PM
B19CivicHB's Avatar
Default When is a MSD type ignition necessary?
Is it really only necessary for FI or NOS? Thanks.
Old Nov 26, 2001 | 06:01 PM
Max GSR's Avatar
Default Re: When is a MSD type ignition necessary? (B18CivicHB)
It's really only necessary once you've brought the motor waaay past it's original design specs. That can be for high-compression NA or FI applications where you HAVE to have the spark when you NEED it or risk detonating your motor!
Old Nov 26, 2001 | 06:03 PM
B19CivicHB's Avatar
Default Re: When is a MSD type ignition necessary? (Max GSR)
thats what i though... thanks for confirming it!
Old Nov 26, 2001 | 07:56 PM
rainforest's Avatar
yeah if you are running 12.1 comp or more i would suggest a hondata or a msd set-up.
Old Nov 26, 2001 | 09:19 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: When is a MSD type ignition necessary? (rainforest)
hondata needs to crack the 96 accord ecu code damnit.
Old Nov 26, 2001 | 10:24 PM
One8Hatch's Avatar
New User
what do you mean, msd type ignition? i sit a msd distributer, or something like the 6al, blaster 2, 8.5 wires ect? im in the process of uping my compression to 11.5.1, im running stock ignition system right now, what possibilitys could happed if i run the stock ignition for a little bit till i get the funds to upgrade? thanks
Steeve_Civic
Engine Management and Tuning
Nov 22, 2011 08:20 AM
Teamdiesel
32
Dec 8, 2007 04:45 AM
DarkSol97
Dec 7, 2004 08:11 AM
out_of_order
Apr 18, 2004 08:26 PM
RAWB
Nov 26, 2002 01:14 PM
