Buddy Club short shifter reviews?
yeah, i'm using the buddy club shifter in my DA. the quality is great, and the throws are real short, but it has major clearance issues with my exhaust (60mm). I had to cut off the counterweight on the shift linkage, which freed up 5th & reverse, but the shift linkage still makes direct contact with the exhaust piping in 1st-4th. THis leads to a rattle in low rpm's and during warm up, which can get pretty annoying. I will eventually grind down the shift linkage, but havent had time.
this is on a DA. you might want to check to see if the shifter to exhaust clearance is the same or not if you have a DC.
kojack_0
19
Dec 4, 2008 09:16 AM
erikiksaz1
Mar 28, 2005 01:51 PM
charjacq
Apr 27, 2002 12:32 PM
