dropped 03 accord
what do you guys think about ground control coilovers on an 03 accord coupe? I want coilovers that aren't too expensive but aren't too cheap....I also only want to spend a 400 dollar limit...need some feedback and/or suggestions..thanx
make sure you get some good shocks... but i would recommend saving up some more $$ and get the tein coilover/shock combination... invest in a camber kit and front strut tower brace and your car should be much funner to drive... i have neuspeed race spring/bilstein sport shock/eibach camber kit (rear)/neuspeed front strut tower brace and i enjoy every single curve out on the road.
thanx!....but all that is still alot of money and i would like to drop the car a little sooner....would adding only coilovers and leaving everything else stock like camber and struts mess up my car??
No, but it will prolly wear ur struts out pretty quick, and may eat your tires up depending on how low you drop it. Just get an alignment after you get it done.
thanx again for the information...i also did some more thinking and researching since i am on such a tight budget, should i just get some eibach sportlines and get the alignment done and leave the rest stock....need some advice ...
no, but sooner or later, the stock shocks will have too much travel and they'll bottom out, plus i don't know about ground controls, but on the race springs, they were so stiff that the stock shock can't keep up with the springs so you'll experience some bounce.... but if you want to do suspension do it right the first time because not only will it enhance performance, but its also SAFETY
thanx for the advice...i might get the eibach sportlines, h&r race springs or tein s tech, and some non-adj or adj shocks, depending on my budget lol......any more suggestions would be nice..thanx again
honda607
Jun 7, 2003 07:17 AM
