A d15b swap problem.
Old Jul 25, 2004 | 09:29 PM
Destroyer24Seven's Avatar
Default A d15b swap problem.
Whats up fellas. I have a problem with my swap. This weekend me and my friend put a d15b (vtec) into my 91 civic si hatch. The swap went pretty smoothly. Pulled the old one motor. Then swapped the wiring for the si motor to the d15b. Everything for the most part wired up and clipped in. I also used the obd0 si distributor. So we go to start it, starts up alright but doesn't rev good and it was also throwing tps sensor. It boogs down when I let the clutch out basically. So today I fixed the tps sensor no code. But now it bearly runs at all. So I replaced everything today new plugs,cap,rotor. Still nothing. Also checked all grounds, even switched around sensors like the map,tps, and a few others.
I was hoping you guys could shed some light on this problem.
Maybe some one has had this same problem.
Old Jul 25, 2004 | 09:32 PM
mr. carpenter's Avatar
Default Re: A d15b swap problem. (Destroyer24Seven)
how did you set the timing? may be off at the crank? also how did you mount the dist.?
Old Jul 25, 2004 | 09:38 PM
Default Re: A d15b swap problem. (mr. carpenter)
Well the mount points on the dizzy where different so we made the si dizzy fit. I tried to fix the timing by moving the dizzy back and fourth it didn't make it much better.
Help!!
Old Jul 25, 2004 | 09:39 PM
Synth124's Avatar
Did you place the rotor on the correct way? If you don't mark it or remember which way it goes on, you can put it on 180 degrees off.
Old Jul 25, 2004 | 09:47 PM
Default Re: A d15b swap problem. (Synth124)
Yeah replaced it right. It acted the same way before I changed the rotor. Another weird thing is when I put the tps back the way it was when it throw the code. It idles fine, but it falls on its face when Im drive it. Right when I let out the clutch.
Old Jul 25, 2004 | 10:29 PM
Come on.
Old Jul 25, 2004 | 10:38 PM
Dyn0speed's Avatar
how is it like
Old Jul 25, 2004 | 10:46 PM
Default Re: A d15b swap problem. (Dyn0speed)
Yeah it runs like crap. If I rev it the car dies.
I don't know why I projected my daily driver. Now I riding my bike to work.
Old Jul 26, 2004 | 02:03 PM
I wondering now if its that dizzy. Has anyone successfully done a d15b swap with an obd0 dizzy? This swap has got me stumped. Any help would be great thanks guys.
Old Jul 26, 2004 | 02:11 PM
Jester88Si's Avatar
The ignition maps are probably off, it would probably run its best if you converted to OBD1 and used its ECU and dizzy
Old Jul 26, 2004 | 02:35 PM
Default Re: (Jester88Si)
I still have some of the wiring and the dizzy. Can I just make the obd1 dizzy use the obd0 plugs? Or is that not possible.
Old Jul 26, 2004 | 04:07 PM
temp's Avatar
Default Re: (Destroyer24Seven)
run it obd-1, dont run it ghetto
Old Jul 26, 2004 | 04:13 PM
fourthgenhatchB17's Avatar
Default Re: (temp)
I have plenty of D15b swaps using the obd-0 dizzy and pm6 (88-91 si ecu). It should run fine. Although converting to obd-1 is a great idea, it should still run very strong with the obd-0 set up.
Old Jul 26, 2004 | 04:15 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">I have plenty of D15b swaps using the obd-0 dizzy and pm6 (88-91 si ecu). It should run fine. Although converting to obd-1 is a great idea, it should still run very strong with the obd-0 set up.</TD></TR></TABLE>
running it obd-0 is still ghetto
Old Jul 26, 2004 | 05:12 PM
Default Re: (temp)
Do you guys know of any reason why it wouldn't be running right though. I have checked and re checked everything. Can I maybe use the obd1 dizzy and just covert the plugs that go into the harness to obd0. I checked and all the wires for the two dizzys and they look the same. I think I saw a topic on this the other day. I will search to try to find it. If you fellas have any related material it would probally help. thanks.
Old Jul 26, 2004 | 05:16 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Destroyer24Seven &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys know of any reason why it wouldn't be running right though. I have checked and re checked everything. Can I maybe use the obd1 dizzy and just covert the plugs that go into the harness to obd0. I checked and all the wires for the two dizzys and they look the same. I think I saw a topic on this the other day. I will search to try to find it. If you fellas have any related material it would probally help. thanks.</TD></TR></TABLE>
because you are running it OBD-0 with the wrong ECU
Old Jul 26, 2004 | 05:43 PM
Default Re: (temp)
Which ecu should I be running if all the wiring is obd0?
Old Jul 26, 2004 | 06:24 PM
Jester88Si's Avatar
I don't think it'll ever run as it should with an OBD-O setup how would you use activate VTEC a ghetto switch? No you cannot use the OBD-1 dizzy with an obd0 setup convert to obd1 and use a p28 ecu if you dont have the d15b's ecu. It'll save you alot of headaches.
Old Jul 26, 2004 | 08:06 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Destroyer24Seven &raquo;</TD></TR><TR><TD CLASS="quote">Which ecu should I be running if all the wiring is obd0?</TD></TR></TABLE>
no ecu, as a matter of fact just take the engine out of the car if you dont want to do it right
Old Jul 26, 2004 | 08:32 PM
Jester88Si's Avatar
There is no OBD-0 ecu that would work properly with the d15b convert to obd1....
Old Aug 3, 2004 | 11:51 AM
Tad's Avatar
Tad
did you set the tps voltage?
if not that will make a SEVER impact on your motor.
like running AT ALL vs running perfectly
and everything imbetween.
if not i'll give you some tips on how to do it.
Old Sep 6, 2004 | 09:56 PM
blo2k1's Avatar
Default Re: (Tad)
hey whast up just wondering how do you set the tps voltage and where should it be at? this is aon a sohc vtec d15b
SYTFU Tommy.
Apr 25, 2007 11:21 AM
janz3n
Apr 11, 2006 08:06 AM
pokemon
Jun 27, 2003 11:36 AM
blacksoul
Sep 10, 2002 08:25 AM
