ZC
I had another thread but I don't know where its gone.
with a zc engine in a crx can I use a normal crx header? if I want to replace the clutch would I get one for an integra? would a normal cold air intake for the crx si work with the zc?
Thanks, Eric
Thanks, Eric
use a normal CRX Si header, however, if this is a DOHC ZC the exhaust ports are offset about 3mm from the Si ports and depending on the header you get, you may have to grind out the ports on the header slightly to match the head - use clutch for same year as your CRX - normal Si CAI fits just right
civicracer1993
Nov 3, 2003 07:59 PM
